Timing chain
Old Feb 16, 2008 | 07:26 AM
rickysvette427's Avatar
rickysvette427
Default Timing chain
I have a 94 with 81,000 highway miles. I'm getting ready to replace the water pump and opti spark, should I replace the timing chain also. Nothing has ever been replaced all orginal.
Old Feb 16, 2008 | 08:07 AM
JackDidley's Avatar
JackDidley
My common sense says change it. A good one is $100. On the other hand, I did mine when I did the cam at 85000 miles the and chain was in very good shape. Never expected that. I put it in just to be safe. You should do it too, since you are going to be almost there anyway.
Old Feb 16, 2008 | 11:46 AM
Hotred94's Avatar
Hotred94
I would. =)
Old Feb 16, 2008 | 12:04 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
No need to, they're good for 150k+.
Old Feb 17, 2008 | 12:24 PM
Hotred94's Avatar
Hotred94
Stretch is what determines when a chain needs to be changed. My 94 with 90,000 was plenty stretched.
Old Feb 17, 2008 | 12:44 PM
zr1fred's Avatar
zr1fred
Most of the stetch occurs within the first 10k miles. In the old days with the nylon gears 100k miles or 10 years was pretty much the limit. With todays clean burning engines and steel gears, they can last a very long time, it's very rare to have timing related problems (don't get me started on timing belts!). If It's a worry, change it.
To Timing chain
