1988 windo rattle
I have a stock 1988 coupe that has a driver’s side widow rattle when the window is partially down. I took off the door panel and found that the glass will hit the two bolt ends that hold on the side view mirror. I checked the other door (which does not have the problem) and can not see any difference. The anti-rattle pads seem to be in place. Any help or suggestions on this would be really helpful; I just do not have any experience with this type of repair. THANK YOU!!!
