Rear Bearings again
Old Dec 4, 2001 | 10:29 AM
Jim D's Avatar
Jim D
Default Rear Bearings again
Well after 3 hours with my son we couldn't get the top torx bolt to break, my son was bending the 1/2" breaker bar, after dropping the spring and tie rod I was able to get my impact gun on it 125 psi , it didn't move.. I think my options are heat , will this harm anything, or cut the bolt at the hub and drill out, Will I be able to put a new bolt in without dropping the half shaft? Thanks for all the help as usual Jim
Old Dec 4, 2001 | 02:20 PM
bogus's Avatar
bogus
Default Re: Rear Bearings again (Jim D)
USE HEAT!!!!!!
Just keep the heat away from the brakes...
focus the heat on the iron of the bearing and away from the aluminum...
also, get another cheap T55 socket. If it is worn, it my not be getting the bite.
