car won't start
Old Feb 18, 2008 | 10:47 AM
BEZ71's Avatar
BEZ71
Default car won't start
just put in new batt. when i turn key nothing radio works have lights (no interior lights when door open) can't figure it out any ideas?
Old Feb 18, 2008 | 10:55 AM
PurtyLilC4's Avatar
PurtyLilC4
checking the connections to the battery again and checking the fuses are the first things that come to mind, and if it an automatic make sure its in park or neutral. I'd have to think some more on it if thats not the case.
Old Feb 18, 2008 | 11:17 AM
BEZ71's Avatar
BEZ71
what fuse would stop the starter from engaging?
Old Feb 18, 2008 | 11:37 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Sounds like a bad connection somewhere. You'll need a wiring diagram and a test light to track it down. You might start by checking the fusible links near the battery.
Good luck, Paul
Old Feb 18, 2008 | 11:47 AM
BEZ71's Avatar
BEZ71
its amazing how a car can go bad by no being started for 3 months!
Old Feb 18, 2008 | 05:42 PM
BEZ71's Avatar
BEZ71
the alarm light in the dash does not flash, nor does the lights turn on when door is open turning key yields nothing not even a click. every other electric devise works radio,ant.,windows,horn. i'm stumped
Old Feb 18, 2008 | 11:23 PM
jfb's Avatar
jfb
Always include the year C4 you are asking help for, no one here is clairvoyant and all C4's are not exactly alike!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Unplug the clutch safety switch (gear selector switch at base of shift lever if automatic) and jump the wiring harness plug. Measure the voltage on the jumper with ign sw in crank position. If you have 12v and no cranking, then you have a defective starter/start solenoid. If no 12v, then remove the kick panel above the drivers feet and find the 2 wires from above the steering column that plugs into a 2 pin connector and unplug it. Insert your ign key and measure the resistance across the connector from the steering column. It should measure the same as the pellet in your ign key. If it is more than 4% from the pellet resistance, you need a new ign lock which will have new contacts that make connection to the pellet. You can temporarily bypass VATS (depending on what year your C4 is) by connecting a fixed resistor across the 2 pins on the connector from the wiring harness the same value as your pellet. Don't permanently bypass VATS because 99% of thefts are done by bashing the ignition and jumping the ignition. VATS prevents this.
If you would bother to use the search function you would have found my above instructions about 320 times! But, I do hope this info helps you.
Old Feb 23, 2008 | 08:54 AM
jjarrett's Avatar
jjarrett
Default no start
hi bez71! i have a 90 that is doing the exact same thing!! it has even been sitting for 3 months! when i get this thing fixed it will be sold! i'm too old to let something like this worry me. i have a 76 that does not have all this electronic crap on it.---good luck and have a great day!====john
Old Feb 23, 2008 | 09:39 AM
Da Mail Man's Avatar
Da Mail Man
.....still, it sounds like a crap connection at the battery..
Old Mar 2, 2008 | 07:24 PM
BEZ71's Avatar
BEZ71
changed the bolts on the cables and even tried to jump with other car nothing. everything works except, alarm,dome lights,visor lights. i guess i will take it in when the weather breaks. thanks all
Old Mar 2, 2008 | 08:51 PM
jfb's Avatar
jfb
Wait until you see their bill
Instead, why don't you try the diagnostic process I posted above?
Old Mar 18, 2008 | 09:42 AM
Radco10's Avatar
Radco10
Check the L.C.D. fuse first. Let us know what you find.
To car won't start
