113 casting max lift
Old Feb 19, 2008 | 03:48 PM
chad89's Avatar
chad89
Default 113 casting max lift
I would like to Know what the consensus is for max lift on stock 113 casting heads before retainer to valve guide interference is an issue. This is assuming new springs such as comp cams 941's (or insert your recommendation here, looking to get around .525 lift with hyd. roller) set at a installed height of 1.75 and a safety margin, of what, .06, with coil bind at 1.13
I realize the only true way to know is to measure, and that heads vary from set to set but I am interested in what has been your experience. I have kind of always heard that on most stock heads you can get away with around .480 lift, but I have also heard that the 113 casting may have a little more room cast in.
Old Feb 19, 2008 | 08:33 PM
racebum's Avatar
racebum
the other question is where the flow stalls. I ported the living hell out of a set of 113 castings, used the necked down 1.94/1.50 valves and brought them up to 232@.500 and 191@.500, the exhaust went up some by .500 but the intake was down @.550. the ports are so small that they stall and back up by .550 lift. If i remember right .550 lift was 225ish on the intake, nothing drastic but enough to realize a cam over .500 lift is a waste of energy. Comp cams has a 224deg lobe with .502 lift that works really well with these heads. you could do a 224/224 custom grind if you have a fast exhaust port and good exhaust or 224.230 if your exhaust is a little behind the times.
Old Feb 19, 2008 | 09:04 PM
chad89's Avatar
chad89
The heart of my question is how much lift is possible without retainer to valve guide interference? Without having to machine down the guide.
Old Feb 19, 2008 | 09:25 PM
pr0zac's Avatar
pr0zac
what cam do you you want to use?
Old Feb 19, 2008 | 10:30 PM
89onlyZ51's Avatar
89onlyZ51
You can pop the ZZ4/LT4 springs and retainers in a 113 head and be good for .525 lift. I don't know about the other retainers from comp, crane, etc.
Old Feb 20, 2008 | 03:00 AM
racebum's Avatar
racebum
.525 is the most i have personally seen. no idea what the real max is, like i was saying though, why go over .500?
Old Feb 20, 2008 | 06:01 AM
pr0zac's Avatar
pr0zac
why not.. i am sure you could go to .550 without issue as long as you have the correct springs.. i think vortecs are the only ones with lift issues straight out of the box.
Old Feb 20, 2008 | 09:45 AM
89onlyZ51's Avatar
89onlyZ51
The 113 heads stall flow right about at .500. That means the flow is the same at .500, .600, .700 (if you could get there). A lower-lift valvetrain is easier to build than a higher one, so you'd be spending extra $$ for absolutely no benefit.
Old Feb 20, 2008 | 09:58 AM
The Bus's Avatar
The Bus
I ran my 113s with a max. of 0.570 lift. That's including the 1.6 roller rockers. I used [ per Comp Cam recommendations ] LS1 beehive valve springs. I ran them for two years with NASA racing events. The engine spends most of it's time above 3000 RPM NO PROBLEMS
Since then I purchased AFR Heads. I'll see this March on the Dyno if that was a wise investment. I was hoping for 40 RWHP but everyone says I'll be lucky to get 25. RATS More wasted $$$.
SuperRam
Comp Cam
AFR 195
I'll let everyone know the added HP I get.
Old Feb 20, 2008 | 11:11 AM
tequilaboy's Avatar
tequilaboy
On my 88 113s using LT4 springs/seats/retainers:
Edited my post after I took a look at some old photos that I took. Its tighter than I thought.
I had cut a card to fit between the seal and the retainer to serve as a crude thickness guage, and I had taken a picture of the card thickness with respect to a steel rule. From the picture the card was 9/16" thick.
I only had about 9/16" (0.5625) from the guide to the retainer on the exhaust valves.
For me this was too tight to run the factory intake style seals also on the exhaust valves, since the seal reduced the clearance by about 1/16". The resulting retainer to seal clearance was insufficient for 0.510 lift.
The intake valves had approx 9/16" (0.562) of clearance with the seals in place.
It seems that the guides are machined differently for the intake and exhaust. Something to consider if you wish to run seals on the exhaust.
Just be sure to check your heads with your retainers at install time.
Comp 503 cam with 1.5 rockers (0.503/0.510 lift)
Old Feb 20, 2008 | 11:39 AM
chad89's Avatar
chad89
"For me this was too tight to run the factory intake style seals also on the exhaust valves, since the seal reduced the clearance by about 1/8". The resulting retainer to seal clearance was insufficient for 0.510 lift"
tequilaboy,
So did you run a different type of seal on the exhaust side?
Old Feb 20, 2008 | 12:04 PM
tequilaboy's Avatar
tequilaboy
I used larger oil shields from Comp Cams on the exhaust valves to complement the square-ring valve stem seal similar to the factory arrangement.
The oil shields that I used were a lttle big for the springs 1.43" dia. IIRC, but it doesn't seem to be a problem.
Old Feb 20, 2008 | 02:23 PM
ultraviolet70's Avatar
ultraviolet70
Originally Posted by tequilaboy
On my 88 113s using LT4 springs/retainers:
tequilaboy
What valve spring seats did you use with this?
Old Feb 20, 2008 | 02:39 PM
tequilaboy's Avatar
tequilaboy
I also used the LT4 seats. I went back and edited my initial post after reviewing some old pics. The clearance was more like 9/16" (0.5625) instead of 5/8".
To 113 casting max lift
