chip for a 92 iroc same as 91 vette?
If comparing stock for stock, the Vette chip has very different programming from the F-body on account of the alum heads.
Different spark / fuel programming ( more aggressive ) to start with.
TCC , EGR nearly every setting is different
Stock F-body chip would prob run car slower in Vette.
The Vette ECM has a data link to the CCM that the F-body doesn't.
Roy
However as I previously posted there can be lots of variations even in the same model as to auto / man , fed / ca emisson , etc calibrations.
Any chip should start and run the car but will not be optimum for either perf or economy
They also don't use the "same" computer. The vette uses a '727, which
is damn similar. For example, I can run a Vette binary in a '730 ECM
(which oddly enough I'm running on my '87 vette), but there is some
inputs that only exist on the '727. You can't interchange them, the connector is different. ('727 being a weatherpak ECM)
For $10, if its a complete chip with a resoldered prom it's a steal. Not because of the programming, but because finding
730/727 memcals has become a PITA, and it's always good to have a backup memcal. If it has a soldered
ZIF on it it's an even better deal. You could buy it, and turn a profit.
-- Joe
