Need Help #5 & #7 Dead Lt4
Old Feb 19, 2008 | 11:08 PM
austin8388's Avatar
austin8388
Navigator
Default Need Help #5 & #7 Dead Lt4
1996 LT4 with 46,000 miles. It's mostly stock. 5 and 7 cylinders are not firing. #5 is misfiring twice as much as #7 but both not working. I replaced opti-spark, all wires and plugs. Test lights show both 5 and 7 injectors are getting power. I swapped out good injectors in the bad cylinders but still have same issues. I guess a compression check is next. There is no smoke from the exhaust and no oil in coolant or coolant in oil. ANY IDEAS?????? Thanks in advance.
Old Feb 20, 2008 | 10:59 AM
bad-zr1's Avatar
bad-zr1
Just a quick thought, make sure they are not swapped. 5 and 7 are the easiest to get mixed up as they are next to each other in the firing order.
Old Feb 20, 2008 | 01:58 PM
all4c4lt4's Avatar
all4c4lt4
Old Feb 20, 2008 | 02:34 PM
96GS#007's Avatar
96GS#007
Originally Posted by all4c4lt4
Old Feb 27, 2008 | 08:51 PM
austin8388's Avatar
austin8388
Navigator
Ok. swapped 5 & 7. Same results. Checked compression on all odd cylinders and all readings are correct. I drove it for about 20 miles and got no improvement. Maybe it is an electrical issue in the harness.....? I think 5 and 7 injectors are are tied together but not for sure. I'm out of ideas. Anyone?
Old Feb 27, 2008 | 11:00 PM
Quiktrp94's Avatar
Quiktrp94
Valve spring or rocker? Can't imagine anything else.
To Need Help #5 & #7 Dead Lt4
