Flushing Brake Fluid
Old Feb 21, 2008 | 12:14 AM
wheelhorse's Avatar
wheelhorse
Default Flushing Brake Fluid
I did a search on this topic and just spent 3 hours reading different member info. Flushing vs. bleeding, speedbleeders, Sears vaccume pumps etc. All good stuff. I'm getting ready to do my 95. I'm putting new roters, brake pads, shocks and tires. It's up on jack stands now. I'm leaning toward the speedbleaders. I have the FSM for the 95 and will follow their sequence rr,lr,rf,ff. I'm not concerned about the ABS. My guestion is, do you leave the cover off the MC and push gently? I did not come accross this in my search and the FSM does not mention this. Thanks
Old Feb 21, 2008 | 01:05 AM
Sam Lam's Avatar
Sam Lam
I cannot answer to using speedbleeders.....as I have not used them. However, do not leave the cover off the MC as brake fluid absorbs moisure from the air. Moisture in the brake fluid turns the fluid acidic over time and this is not desirable for your brake system.
Old Feb 21, 2008 | 01:12 AM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
You can just set the cover on the MC. I don't think you have to secure it each time. Just keep it filled and don't let the MC run out or else you'll get air back in the lines.
Old Feb 21, 2008 | 01:15 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
If you are doing all of that, get the speedbleeders, they work great. A vacuum pump is a good investment w/ our cars, helps when changing rear end fluid, ect. You may also want to get some stainless steel brake lines, also very worth while, and Hawk HPS pads.
When I changed out everything, I couldn't believe the difference, best thing I ever did to the car.
Old Feb 21, 2008 | 08:57 AM
Chatman's Avatar
Chatman
Do put the cover in place when pumping. Otherwise, you can get brake fluid all over the place. Ask me how I know.
Old Feb 21, 2008 | 09:08 AM
tlong's Avatar
tlong
I suggest the Motiv Power Bleeder. It attaches to the top of the MC and pushes the fuid through with a little pressure. You pump it up like a garden sprayer. Just attach the included tube to the bleeder and let it drain until it runs clean.
Speed bleeders work well but require long stroking the pedal, farther than usual, so you could get some crud into the system. Also you have to keep pouring in fluid. The MPB so easy. I used ATE SuperBlue fluid to make the new fluid very obvious. I have flushed my system twice with it and never spill a drop. Great tool for this job.
Old Feb 21, 2008 | 09:25 AM
93 ragtop's Avatar
93 ragtop
I have one of those, but I have never had any sucess getting it to seal to the MC resivour. Any suggestions on what im doing wrong? Thanks
Old Feb 21, 2008 | 09:54 AM
rfn026's Avatar
rfn026
I flush my brake fluid about 5 or 6 times a year. I begin every track event weekend with all new brake fluid. That keeps the moisture content down to about zero. I also only use fluid from a brand new unopened bottle. OK - I'm a little obsessive but then again I've never had a brake problem at the track.
I use the Motive Power Bleeder and have never had a problem with it. I believe that it's better to push fluid through the brake system as opposed to sucking it out.
If you use your Corvette on the street you only need to flush your fluid once a year.
Bleeding your brakes is simply getting any air out of the lines. Flushing is a complete exchange of fluid. You want to get all of the moisture laden fluid out of the system and have only nice dry brake fluid in the system.
Richard Newton
How to Restore and Modify Your Corvette, 1968-1982
101 Projects for Your Corvette 1984-1996
Old Feb 21, 2008 | 10:04 AM
MK 82's Avatar
MK 82
I have bled brakes everyway known to man and pressure bleeding is by far the best!
Old Feb 21, 2008 | 10:48 AM
96vetteLT4's Avatar
96vetteLT4
make sure you have the correct cap for the Motive or else you wont get a good seal. They do make a couple of different ones so if you are having a problem getting it to seal on the m/c that could be it. Mine seals tight and you can tell....G
Old Feb 21, 2008 | 11:34 AM
Sidney004's Avatar
Sidney004
Not necessarily, I use about 6 half strokes; no need to press the pedal down very far using speedbleeders. As for adding fluid, that is the part I like as it purges all the old burnt fluid out of the calipers. I start with a full master cylinder and do not have to retop prior to bleeding out my full brake system. I find that a full 4 wheel bleed uses 6-8 oz. of fluid.
To Flushing Brake Fluid
