where can i get a LT1 intake converted?
Old Feb 21, 2008 | 12:35 AM
19corvette91's Avatar
19corvette91
Default where can i get a LT1 intake converted?
LT1intake.com seems to be gone?
who else offers this service?
Old Feb 21, 2008 | 12:46 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Check over on http://www.thridgen.org. Someone is always selling a used one.
It is hard to believe that someone on this forum, or over at TGO, has not stepped up to fill this void.
You may try to contact forum member Redrose, he is kind of the Godfather of the swap on this forum.
Good Luck.
Old Feb 21, 2008 | 12:58 AM
rodj's Avatar
rodj
With information available online , you should be able to get any competent engineering shop to do the work required.
Less fussy people have done the with hand tools
Old Feb 21, 2008 | 03:16 AM
red L98's Avatar
red L98
i can have my guy do it for you
Old Feb 21, 2008 | 06:54 AM
19corvette91
red L98...let me know how much
i live in NJ, finding somebody competent around here is grasping at straws.........LOL
Old Feb 21, 2008 | 07:43 AM
MR NICE's Avatar
MR NICE
If you don't have a intake yet your best off getting a complete intake setup,quite a few on e-bay or check your local bone yard.Make sure it came off a 350ci engine,there is a number to look for but have forgot what it was,a search will come up with it.then you need to decide large or small dizzy,best off to research this board for info needed.I have pics ,if you want send me your e-mail.
Old Feb 21, 2008 | 07:59 AM
armybyrd's Avatar
armybyrd
Is one off of a '94 Caprice the same? I know that as long as its '94-96 its fine, not sure about it as mines from a Caprice though. Any differences?
Old Feb 21, 2008 | 02:47 PM
MR NICE's Avatar
MR NICE
Should be ok if it was a 350 ci .
Old Feb 21, 2008 | 03:43 PM
rlane5's Avatar
rlane5
19corvette91, I have one I'm thinking about selling and I live in central N.J. Email me at Lane53099@yahoo.com if interested.
Randy
Old Feb 21, 2008 | 03:45 PM
Demonic85's Avatar
Demonic85
Yes the fuel rails are different.
Old Feb 23, 2008 | 01:41 AM
red L98's Avatar
red L98
around 200
Old Feb 23, 2008 | 11:39 AM
redrose's Avatar
redrose
casting numbers are on the manifold/cylinder head bolt flange, pass side , abt half way from front to rear...350's "should" have an eight-digit casting number 1010xxxx (just the first four digits are all you need to look for)...some of the 265 c.i. ( L99 ) engines also got the 350 intake but a very, very few of the 350's got the "small" intake, check numbers on the injectors if re-using those...the 350 and 265 intakes show in the "interchange" books that the j-y's use as being the same and they will in fact "bolt up", check the casting numbers first.
To where can i get a LT1 intake converted?
