Newbie!!
Old Feb 22, 2008 | 09:25 AM
jtkal's Avatar
jtkal
Cruising
Default Newbie!!
Thank goodness I found this sight. Recently purchased a 92 vette. Dang near flawless............ Car runs awesome, however, waiting in long lines after a road trip the temp. max's out. Thermo. is good........what is going on?
Old Feb 22, 2008 | 12:17 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Is the radiator fan coming on?
Paul
Old Feb 23, 2008 | 11:23 AM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
Pull your fan shroud and check the radiator for debris, this is common for the C4's.
Old May 13, 2008 | 01:07 AM
mechguy79's Avatar
mechguy79
Well, if you haven't fixed this yet I think if you ground the ALDL pins A & B, turn the key to on (do not start it) then as the car goes into diagnostics mode the cooling fans should start. I think it's a check spacifically for that purpose. Hope this helps.
To Newbie!!
