HELP? 1996 CE Coupe Upper Control Arms
Old Feb 26, 2008 | 11:56 AM
ukzo6vette's Avatar
ukzo6vette
Default HELP? 1996 CE Coupe Upper Control Arms
Will someone give me some assistance, I know I have done a stupid thing, but without thinking, I have removed both front upper control arms to replace with poly bushes and have removed all the shims on both sides, that is left side shims which sit on both bolts and right side without taking any notes or pics of how many are replaced on each bolt, I don't mean the washers, I know where they go.
I need to know how many shims fit on the left front and rear bolt and the same on the right side, hopefully most of the stock 1996 CE coupe's set up will be identical
Thanks in advance
Old Feb 26, 2008 | 12:19 PM
GS023's Avatar
GS023
Replacing the bushings you would most likely need to re-align any way. The only thing is the conical washers differ. The thick one goes to the inside front bolt.
Old Feb 26, 2008 | 02:37 PM
corvette1989bham's Avatar
corvette1989bham
are you sure the thick one goes to the front . . . .and by that you mean the bolt closest to the front end of the car . . . right? Mine thick ones are on the rear bolt (closest to the firewall) and the car aligned fine at the shop. (this is on my 89 car)
To HELP? 1996 CE Coupe Upper Control Arms
