Cam Selection 95 A4
Old Feb 26, 2008 | 08:46 PM
catlettlt1's Avatar
catlettlt1
Default Cam Selection 95 A4
What cam can i use on a 95A4 without putting in a stall converter ? Myplan is to do LT headers ,1.6 rr ,springs and a cam, no head work just those mods and a PCM tune of course . Will it give me 300 HP at the wheels? I have searched to no avail ?
Old Feb 27, 2008 | 04:16 PM
hgh pwr's Avatar
hgh pwr
With most cams above stock you will need a converter,I have the hot cam and have had a 2600 stall and it works great.
Are you against spending the money? or are you afraid of some drivability problems with the higher stall?
If you drove my car with a 3000 stall I doubt you could tell it was in there if you didn't know.
you will get some good increases with the long tubes and the rockers but I don't think 300 rwhp but maybe. good luck
Old Feb 27, 2008 | 04:45 PM
vader86's Avatar
vader86
You can get the 300rw with hotcam and those other mods on a dynojet, but it needs a higher stall converter as it comes off the factory line. Anything you do to it now will respond far far better to a higher stall TC.
Old Feb 27, 2008 | 06:54 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
IMO you can do everything except the cam without a higher stall. But, it will work better with it.
Old Feb 27, 2008 | 11:16 PM
catlettlt1's Avatar
catlettlt1
Looks like a project for next year. I just don't fell like going into the transmission right now, due to to time and $$ thanks for the replies.
Old Feb 28, 2008 | 01:00 AM
James93LT1's Avatar
James93LT1
Veteran: National Guard
1.6 roller rocker, springs, tune and gears. When you have enough money, cam headers and stall.
To Cam Selection 95 A4
