Rough idle--opinions?
Old Feb 27, 2008 | 05:23 PM
DougSilver's Avatar
DougSilver
Default Rough idle--opinions?
I have a 95 LT-1 that has generally been running great. I have suddenly developed a rough idle at a stop in gear. My impression is that it is not electrical (it feels different to missing I have had in the past due to bad plugs or wires). The car starts fine and runs fine and the idle is fine until after the car warms up. What happens then is a regular roughness at a stop, like while waiting at a light. The unusual thing is that when this is happening, the slightest touch on the gas pedal will result in the car really lunging on the takeoff. If I stop only briefly, the response from the gas pedal is normal. It is only after idling for a minute or so that the pedal seems unusually responsive.
My own thought about this is that the engine is getting too much gas at idle and the addition of air by touching the gas pedal results in the lunge.
Are there some clever diagnosticians out there who have a better idea of what is happening and why before I bring the car to the mechanic?
Thanks,
Doug
Old Feb 27, 2008 | 10:37 PM
evmlarry's Avatar
evmlarry
Did you check for any stored codes yet by chance?
Old Feb 27, 2008 | 10:55 PM
DougSilver's Avatar
DougSilver
I checked for codes using the paper clip method and found none. This was no surprise as there have been times in the past where the car was running horribly (due to shorting spark plug wire or something else) and no codes were thrown. It seems that there has to be something really catastrophic for the computer to finally throw a code.
Doug
Old Feb 28, 2008 | 06:55 AM
1955VETTE2007's Avatar
1955VETTE2007
Cruising
sounds like an injector is leaking into the cyl . testing the ohm reading on the injector won't tell you if you have a leaker. rule every thing out and check those last because of the big job to replace them
Old Feb 28, 2008 | 04:44 PM
DougSilver's Avatar
DougSilver
It's interesting that as I was driving today and trying to analyze the miss, I actually thought it could be a leaky injector. I was going to try the ohm test since in the LT-1, the injectors are right there and easy to test. But if the ohm test doesn't tell anything about leaking, then I guess I shouldn't bother and just bring it in to the mechanic.
Doug
Old Feb 28, 2008 | 07:04 PM
Weav's Vet's Avatar
Weav's Vet
I had a similiar problem when I got my vette back in Nov. I think the previous owner had been running a low octane fuel. Exhaust tips were black. I ran a couple of cans of Seafoam through it (I'll get slammed for that, I'm sure) At 2000 mile intervails on a full tank with each one. That helped a lot. I disconnected the battery to reset the codes a couple of times since Nov. That also seemed to help. The biggest help was cleaning out the mouth of the TB. Get back in there as far as you can. That made a huge difference in the way it idled.
Old Feb 28, 2008 | 09:23 PM
DougSilver's Avatar
DougSilver
I should have mentioned that the missing started after adding some PurEscape into the gas. I had done this before and was pleased with the results the first time. Also, I only added 1/2 the bottle. Nevertheless, it seems too much of a coincidence that the missing started when the PurEscape was added.
Doug
To Rough idle--opinions?
