95 C4 rear hatch opens while driving
Old Feb 28, 2008 | 06:58 PM
rlm326's Avatar
rlm326
3rd Gear
Default 95 C4 rear hatch opens while driving
I must have an electrical problem (or an invisible trunk monkey).
I'm doing 75 on the Interstate during rush hour and my rear hatch
opens. I pulled over and can hear the rear release cycling as well
as my door locks. It happened again the next time I put the key
in the ignition (release and door locks cycling). Also, the PKE system
light on the message center comes on when this happens.
I seem to have solved the problem by removing the battery from my PKE remote. Do I have an electronic module going bad? Has anyone ever had this problem?
Red on Red 95 LT1 w/103K miles.
Old Aug 11, 2011 | 02:31 PM
gungatim's Avatar
gungatim
did you ever solve this? my 95 is doing the same thing, opens while driving and solenoid keeps cycling until I smack it shut. I just put new batteries in my PKE transmitter, but it won't go into the sync mode and sometimes the light comes on but not when the hatch opens.
Old Aug 11, 2011 | 02:54 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
is something loose and hitting one of the switches?
Old Aug 11, 2011 | 05:40 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If by "smack it shut" you mean the hatch (vs a door), I would assume you're having a problem with the hatch release relay. On my 89, it sits VERY close to the receiver for the hatch "catch". At hard enough slam could jar the relay back into the other pole (shutting off the trip circuit by jarring open the relay).
Old Aug 11, 2011 | 09:31 PM
powerpigz-51's Avatar
powerpigz-51
I have had this issue (though not moving) and it was the switch in the drivers door opening that opens the hatch. Cheap plastic junk.
Old Apr 27, 2023 | 02:51 PM
Vicczz's Avatar
Vicczz
2nd Gear
My '96 hatch opened up sitting at a traffic light for about a minute. I guess I'll start at the armrest button to disconnect it but it only happens about every 3 weeks or so.
I heard the top being released with that thud sound but I'm not sure about hearing the actuator unless that is the actuator sound. I'd think the actuator sound would be more of a short motor turning for a second and with my radio on I didn't hear that.
I don't see anything pop up on my screen but I'll have to pay attention to this next time. Any advice always appreciated.
Will the glass blow out if on the highway when this happens? Anyone experience this on the highway?
Old Apr 27, 2023 | 05:57 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
This thread is 15years old and the OP hasn’t been active on the Forum for eleven years. You have an interesting question worthy of a new post where you likely receive more contemporary information.
To 95 C4 rear hatch opens while driving
