Cam - Roller Combo
Old Feb 28, 2008 | 07:20 PM
Master__Shake_'s Avatar
Master__Shake_
Default Cam - Roller Combo
Looking for a cam that will go nicely with a stock 1986 L98 (CI heads) as a basis to start modifications. I'll most likely combo it with 1.6 rockers but I need to get info about reliable cam companies I can check with. Not going for maximum top-end here, just something that will make the motor more torquey overall and some higher-RPM(4,000-5,000) HP without sacrificing a lot of low-end power. If at all possible, numbers I can get ahold of the companies with would be highly appreciated. Thanks.
Old Feb 28, 2008 | 07:31 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
First problem. The contridiction. You want a cam that operates in the higher RPMs, however you're keeping the stock intake, at least that's how I read it.
You won't be happy if you just change the cam.
Old Feb 28, 2008 | 07:41 PM
Master__Shake_
The cam is the beginning of my motor modifications. A starting point, if you will. Eventually, I plan on getting a 52mm TB and cold air intake system, but I need a cam that will get the most out of it. I'm putting 3.73s in when spring arrives and I want hard acceleration, yet it's staying street legal for weekend cruises. If you don't think you agree with my opinion on uses of the cam, then let me know one you would choose to start a project with. I'm kind of going for reactions of "That's pretty quick for a vette.."
Old Feb 28, 2008 | 07:47 PM
jsup's Avatar
jsup
First of all, don't waste your money on the TB, you won't get any gains. The stock 48MM flows 1000 CFM, plenty for a car with minor mods. Until and unless you get to 500HP, the TB won't make a bit of difference. Same with the CAI.
Second, is the car auto or manual? If its is auto, you don't really want to go over the 3.07 that came stock. I'd save my money on that too. ESPECIALLY if you want do to the long cruises. You can get away with taller gears with the stick.
Personally, I'd do head/cam. I'd port the stock intake. I'd then get the front pipe without the pre-cats if long tubes are out of the budget.
Old Feb 28, 2008 | 07:51 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
52MM throttle body is a waste.
Cold air intake is a waste
SAVE YOUR MONEY
www.tpis.com do some research
Tpis has a cam that will help, your heads and intake will limit it's effectiveness. After you have done some study call them.
Old Feb 28, 2008 | 07:53 PM
redfast's Avatar
redfast
i believe he was refering to the tpi, intake manifold, the design of the tpi, allows a certain RPM power band, ex, the tip looses power above about 4,500rpm?? so with that said your cam, choice refers into what your future plans are for your car with said intake manifold and cylinder heads and such, a bigger throttle body..in my experiences only improves the throttle response, not a h.p. gain though.
so with my rambling, theres ppl, here running 12s without cam changes, just the top end bolt ons ex, 1.6/1.7 roller rockers will help out, increasing the lift of the valves, and some intake manifold upgrades, and exhaust upgrades..
Old Feb 28, 2008 | 07:58 PM
jsup's Avatar
jsup
His stock heads will not support 1.6/7 rockers without spring upgrades. just wanted to add that.
Old Feb 28, 2008 | 08:02 PM
ross.rosseland's Avatar
ross.rosseland
Quick for a vette is around 10.99 or better. You'll be doing good to hit 14.99. You might want to reevaluate your goals. If you really want a significant gain, throw a 100 shot on there and hope it doesn't blow up.
Old Feb 28, 2008 | 08:22 PM
Master__Shake_
Not a big fan of Nitrous.. just trying to get some kind of project out of this car. I love the sound a cam makes and I want to get the performance out of the motor, thinking about heads and polished intake runners, with the cam and a new front-Y with hi-flow cat(I have muff-elims and a rear y-pipe already). For the questions, I'm running auto but I still want better acceleration. No go for the TB? It will save money not getting one but I have to know what exactly will work good for my application.
Old Feb 28, 2008 | 08:26 PM
BADDUCK's Avatar
BADDUCK
You need to do some searches and reading. You are not picking up what we are putting down.
Old Feb 28, 2008 | 08:48 PM
jsup's Avatar
jsup
What gears do you have. What's your budget?
Old Feb 29, 2008 | 01:32 AM
rodj's Avatar
rodj
"I still want better acceleration"
Lower gears , street tires and TPI bottom end torque = no traction so you won't be going anywhere except up in smoke.
As stated above; 3.07 is the best alround gears UNLESS you change intake for more revs
Old Feb 29, 2008 | 08:28 AM
JackDidley's Avatar
JackDidley
Very low 14s is normal for a stock 86.
Old Feb 29, 2008 | 02:33 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default car mods
first of all, do you want to continue to pass smog inspections?
second, how are you going to use the car?
A. if you are going for straight line acceleration, do away with the TPI and go mini ram, LT-1 intake. The TPI cam is a special cam, and to improve the engine, you need a cam that is designed to be used on a TPI engine to get max benefit.
The best resource is TPI fuel injection by John Baechtel, available at Barnes and Noble.
B. If you are going for a road car, enjoy the TPI, get a TPIS cam, better heads, big mouth intake, and runners, port the plenum.
The TPI is a PITA to take apart, reassemble, and then do it all over again, so plan your mods carefully.
Your biggest headache will be the brittle wiring under the hood that regularly sees 230 degrees.
Remember, everything you do to this engine is overseen by the computer, so you have to do computer friendly mods that can either be programmed to work with it, or PROGRAMMED TO FIX WHATEVER YOU SCREWED WITH.
Good Luck
Old Feb 29, 2008 | 03:15 PM
JackDidley's Avatar
JackDidley
Think long and hard before you buy parts. Read a lot. Talk to guys. I found that what everybody else wants, is not what I want.
To Cam - Roller Combo
