Service Ride control
Old Feb 29, 2008 | 02:58 PM
chevythunderlt1's Avatar
chevythunderlt1
3rd Gear
Default Service Ride control
I have had this come up on the computer display I have also noticed that my throttle cable is really slack and the pedal is hard and when pressed nothing happens.Are the 2 connected.
Old Feb 29, 2008 | 11:04 PM
Dads90's Avatar
Dads90
I don't think they are related. You should try and pull a code and see what it says. Probably a loose or failing actuator.
Old Mar 1, 2008 | 10:09 AM
c4cruiser's Avatar
c4cruiser
The two are not related. There are cables between the throttle body, acclerator pedal and the cruise control. You may also have a broken accelerator pedal mount.
As far as the SRC light, you need to puill the codes to see what the problem is. There are 13 different codes.
This link will show you how to pull codes. Post the codes that you get and we can go from there.
Old Mar 2, 2008 | 12:20 PM
Aurora40's Avatar
Aurora40
FYI, but if you've started the car up a few times without moving it (3 times), the SRC light will come on because it hasn't received a vehicle speed signal. The fix is move the car.
To Service Ride control
