TPI Intake qustions
Old Feb 29, 2008 | 06:31 PM
sp361t's Avatar
sp361t
Default TPI Intake qustions
I have a 1990 corvette with a TPI. as we all know the TPI intake is very restrictive. I would like to build up a motor for this car and i would like to stay with fuel injection. Does anyone have any ideas about a good flowing intake that wont break the bank and will also fit under a stock hood?
Old Feb 29, 2008 | 06:37 PM
Cyclonite's Avatar
Cyclonite
Welcome,
First, Learn the search feature... It will save you a lot of grief later.
Miniram (MR)
Super ram (SR)
FIRST intake
TPIS and Accell (and maybe some others) have oversized TPI stuff
LT1 intake conversion
Lots and lots of stuff about all of these here.
There's also the Holley Stealth Ram, but it does not fit under the stock hood of a C4
And last theres single plane runners with elbows or plenum conversions.
Old Feb 29, 2008 | 06:39 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
How big is the bank. How hard is it to break?
Old Feb 29, 2008 | 06:51 PM
sp361t's Avatar
sp361t
looking for something around 800 or less i think. are the elderbrock TPI intakes any good or are they just a waist of 700 bucks? i did find a lingenfelter for 1800 haha
Old Feb 29, 2008 | 06:55 PM
vader86's Avatar
vader86
The first question to ask is how much HP do you want it to ballpark?
Second is budget, and how much of the labor can you do yourself?
Old Feb 29, 2008 | 06:56 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You could do the LT1 intake for that if you shop carefully.
Old Feb 29, 2008 | 07:06 PM
sp361t's Avatar
sp361t
if i could get 350-400HP out of it i would be extreemly happy. secound i can do all the work my self. I would like to do a LT1 convertion but most of the intakes i have seen dont have the water snout on the intake its made for the LT1 type water pump. I am real intersted in the elderbrock TPI type intake but im not sure its worth 700+. bt mid-range power is were i would like to be.
Old Feb 29, 2008 | 07:10 PM
BADDUCK's Avatar
BADDUCK
Have you looked at lt1intake.com
Old Feb 29, 2008 | 07:18 PM
sp361t's Avatar
sp361t
yea i have and i have a type of intake like that with the distributor hole cut but no upper water hose snout. Is it hard to add one or even convert the motor to run a water pump with the upper on it?
Old Feb 29, 2008 | 07:28 PM
BADDUCK's Avatar
BADDUCK
I'm not sure exactly what you are saying but they offer a remote thermostat setup.
Old Feb 29, 2008 | 07:42 PM
sp361t's Avatar
sp361t
ok the thermostat housing is what i mean sorry thats what i was looking for is that type of relocation. thanks for your help
Old Feb 29, 2008 | 09:04 PM
rodj's Avatar
rodj
Your intake needs two holes drilled and tapped into the rear water jacket so as to run hoses to the remote thermo housing then to radiator
Old Feb 29, 2008 | 11:19 PM
vader86's Avatar
vader86
Getting 350-400 with an Edelbrock setup is gonna be pretty much impossible without digging into the bottom end...its doable, but probably not what you want. Joe90 has done it, a link to his page is on my site somewhere.
Better bet for a midrange intake capable of this power is the SuperRam. Miniram/LT1 intake is more of a mid to high rpm intake. They would each be suited to different camshafts.
Old Mar 1, 2008 | 09:11 AM
sp361t's Avatar
sp361t
o yea i do not expect to get that power with just a elderbrock intake. i am going to puts heads/cam in it as well i just need an intake that will flow good enough. the lt1 convertion sounds about the best bet.
Old Mar 1, 2008 | 12:14 PM
vader86's Avatar
vader86
Then I would go for heads around 180cc in port size, and a camshaft like the LT4 hotcam or something with around 220 degrees of duration.
It will need a chip after this is done, and another retune after you decide on the intake.
Bear in mind your heads have 58cc chambers, and you need something close or you'll lose CR.
Old Mar 1, 2008 | 12:22 PM
Demonic85's Avatar
Demonic85
I wish they made an LSx style intake for older SBC's. Its the best of both worlds I tell ya.
Old Mar 1, 2008 | 04:05 PM
sp361t's Avatar
sp361t
yea i do to a LS style intake would be nice. I cant belive no one has produced one yet, they make everything else for chevy small blocks. Just wandering but what is the stock cc intake runners on the vortech head?
To TPI Intake qustions
Old Mar 1, 2008 | 04:42 PM
Curveit's Avatar
Curveit
with the last couple of posts. Then there's the BBK we've been waiting to see for years now. How it will perform and when or if it will be released is ??? I read somewhere that LT1.com went out of business or someone else took over, or something, but I don't know myself.
The old Vortecs were 170CC, and run very good but, they require a Vortec specific intake (bolt pattern). The new ones are 185 & 205CC. (I read somewhere the 205s were actually a little larger than advertised.) and supposed to be able to use any bolt pattern. The ports are tall though, and not every intake will match up
Old Mar 1, 2008 | 05:02 PM
redfast's Avatar
redfast
i love my miniram, excellent power all around up to 6k, rpm's. i got mine here in the for sale section acouple years ago for 8 hundred bucks complete, i run the zz-x tpis cam with it,
Old Mar 1, 2008 | 05:48 PM
sp361t's Avatar
sp361t
yea the mini ram idea is what i think i am going to go with it seems to be what i need any other mods needed with the mini ram?
