quick compression question
Old Mar 1, 2008 | 12:53 PM
rube1975's Avatar
rube1975
Default quick compression question
Ok stock L98 bottom end with 49cc combustion chamber what is the compression ratio?
Old Mar 1, 2008 | 01:21 PM
vader86's Avatar
vader86
This is on your 89?
Old Mar 1, 2008 | 04:17 PM
rube1975's Avatar
rube1975
yep
Old Mar 1, 2008 | 05:43 PM
CFI-EFI's Avatar
CFI-EFI
Combustion chamber in the bottom end? The combustion chamber, being in the head is usually considered to be in the top end. No Corvette L98 has 49 cc, combustion chambers, stock. They are either 76 cc in 1985 and 1986E engines and 58 cc in 1986L through the end of their use in 1991. Besides combustion chamber size, the pistons varied, and there were more than just the two compression ratios that only the head change would account for.
RACE ON!!!
Old Mar 1, 2008 | 07:04 PM
vader86's Avatar
vader86
Starting with a 9.5:1, i figure you'd go up about 1-1.5
Old Mar 1, 2008 | 07:16 PM
mgbss's Avatar
mgbss
It looks like on a 350 ci the difference between a 58cc head and a 49cc head with all things being equal you would gain about 1 point 9.55 with a 58cc to 10.6 with 49cc
Joe
Old Mar 1, 2008 | 07:43 PM
rube1975's Avatar
rube1975
so 10.6:1 with stock bottom end and 49cc heads
now that will work with 93 octane and the right cam
correct???
Old Mar 1, 2008 | 10:23 PM
vader86's Avatar
vader86
correct???
After the custom chip, sure.
Old Mar 2, 2008 | 12:48 AM
cmashark's Avatar
cmashark
what did those heads come from? 305?
Old Mar 2, 2008 | 02:13 AM
rube1975's Avatar
rube1975
DART
49cc but 200 intake runner
Old Mar 2, 2008 | 12:51 PM
CFI-EFI's Avatar
CFI-EFI
correct???
THAT (above) is what THIS (below) was asking???
WOW!!!
RACE ON!!!
Old Mar 2, 2008 | 04:23 PM
rube1975's Avatar
rube1975
Originally Posted by CFI-EFI
THAT (above) is what THIS (below) was asking???WOW!!!
RACE ON!!!
yep i think its clear srry if you didnt get it
Old Mar 2, 2008 | 05:01 PM
Curveit's Avatar
Curveit
I don't know how far the valves are off the deck with the smaller combustion chamber in these heads... would valve to piston clerance possibly be an issue with your combo? Depending on the lift of your cam too, of course.
P.S. I think 305s have a 58CC chamber.
To quick compression question
