How much horsepower will the LT4 induction plumbing (air filter, maf, and throttle body) support. You can have terrific heads but if the induction piping can't keep up?
"The 48mm throttle body remained unchanged from the LT1, however all LT4 equipped Corvettes (not just Z16 Grand Sports) featured a throttle body top cover plate with the words "Grand Sport" in red letters."
From what I have heard, the air filter, MAF, and ducting will support quite a bit. I have heard a lot of horror stories about aftermarket MAF's, so I will stick with the stock one on my 383.
It's a lot. More than you'll make with an NA small block.
The only restriction to the MAF is in the tuning tables. I'm not sure what the maximum grams per second of air a MAF will read, but I've seen numbers upwards of 450. The highest grams of air per second number I've personally seen was about 455. The car that produced those numbers made ~450 RWHP.
I really don't think you have much to worry about in the intake plumbing department. The reason you aren't getting answers is because not many people (or maybe no one) has made enough power for it to become an issue.
Guys with 600+ RWHP are always power adder cars, and they have to change the intake tubing to accommodate the forced air plumbing associated with their power adder. Nitrous cars see those numbers sometimes, but they are making the power without having to move a massive amount of air, so none of those guys change the stock stuff either.
Some people run an intake called the SLP claw, but I've never heard of it increasing the HP of the car by a tremendous amount.
