WBO2 logging with LM-1
Old Mar 3, 2008 | 01:33 PM
Sliding's Avatar
Sliding
Default WBO2 logging with LM-1
I've recently bought LM-1 with rpm converter but I can't get it to
work correctly.
Does any of you use LM-1??
Old Mar 4, 2008 | 01:20 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Yes - I use the LM1 with the RPM converter. What type of problems are you having? Is it just the RPM information from the converter that you are having trouble logging, or are you not able to read A/F ratio information from the meter itself?
Old Mar 4, 2008 | 04:30 PM
Rohn's Avatar
Rohn
I use both. What is the issue?
Old Mar 7, 2008 | 04:06 AM
Sliding's Avatar
Sliding
I can log AFR as long as rpm converter is not connected.
As soon as I try to log AFR with RPM I get terrible noise (spikes)
on both AFR and RPM readings.
It got a little better after adding potentiometer (like suggested
on LM-1 forum) but still not usable infos.
I'll try to post my logs later so you'll see what I'm talking about.
Where did you take your rpm signal from?
Old Mar 8, 2008 | 10:19 PM
byebyeL98's Avatar
byebyeL98
Did you properly configure the RPM cable as outlined in the manual?
If so, this could be a grounding issue. How do you have the LM1 meter wired? When I initially started using mine, I plugged the LM1 meter power cable into the cigarette lighter. Turns out the poor ground in the cigarette lighter was causing inaccurate data logs, weird readings, etc. After I hard wired it (and ran the ground directly to the frame), my problems were solved.
I am taking the rpm signal directly from the "tach" terminal in the HEI cap. My MSD 6A box feeds an Autometer tach.
Old Mar 11, 2008 | 12:24 PM
Sliding's Avatar
Sliding
I thought it was ground problem so I wired LM-1 directly to battery.
I have tried with rpm converter grounded, not grounded, it's
the same.
I have configured rpm converter with PC like stated in manual.
Do you use potentiometer on rpm signal?
I have also connected directly to tach terminal on cap.
Old Mar 11, 2008 | 12:47 PM
byebyeL98's Avatar
byebyeL98
I did not use the potentiometer.
Did you go to the Innovate Motorsports LM1 forum to see if you could find an answer there?
Old Mar 11, 2008 | 03:25 PM
Sliding's Avatar
Sliding
Yep, I tried that first.
How exactly did you wire your LM an rpm converter?
Old Mar 11, 2008 | 05:59 PM
Rohn's Avatar
Rohn
At the lead from coil to tach.
To WBO2 logging with LM-1
