Cleaning A arms
Old Dec 6, 2001 | 03:55 PM
Jim D's Avatar
Jim D
Default Cleaning A arms
What should I use to clean the aluminum a arms, and related suspension parts, is there a cleaner , or just wire brush thanks as always Jim
Old Dec 6, 2001 | 03:58 PM
khornet's Avatar
khornet
From: Phx/but its a dry blast furnace kinda heat AZ
Default Re: Cleaning A arms (Jim D)
I used a combo of Oil Eater/Simple Green and a plastic bristle scrub brush. An old toothbrush is handy for the small hard to reach areas.
Old Dec 6, 2001 | 04:00 PM
TennLee's Avatar
TennLee
Cruise-In II Veteran
Cruise-In III Veteran
You can also use a cloth wheel and some aluminum polish.
Lee
Old Dec 6, 2001 | 04:55 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: Cleaning A arms (TennLee)
SImple Green, plus some "00" steel wool, and some Never Dull to get them aluminum parts all nice and shiney.
Old Dec 6, 2001 | 05:55 PM
black bart's Avatar
black bart
Default Re: Cleaning A arms (Vette92)
Polishing is a little more work than I care to put into them but I use simple green or a product called engine brite it is for cleaning aluminum engine like motor cycles makes them look good but if you are willing to spend hours of rubbing they would look better yet.
Old Dec 6, 2001 | 06:34 PM
RichS's Avatar
RichS
Default Re: Cleaning A arms (black bart)
I used a crapload of brillow pads and simple green. Then metal polish. I had move dirt and grease on me when I did my 95 that was on the car. :D
Old Dec 6, 2001 | 08:14 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Cleaning A arms (RichS)
I use never dull(or something similar) I just wipe it on, let it sit then wipe it off. Somehow mine were black, looked like somebody had painted them, because my yellow shocks had black over spray.
Old Dec 6, 2001 | 08:47 PM
mash557's Avatar
mash557
Haven't got to the front yet, but on the back, simple green, followed by laquer thinner, then 180 flap wheel in my die grinder, then wet 400, 600,800,1200 and then get the buffer out. spent about an hour after sanding and they look almost like chrome. I also removed the die flash from the forging process. I know who's gonna see the back...call it practice for the front.
Old Dec 6, 2001 | 09:55 PM
HiRiser's Avatar
HiRiser
Default Re: Cleaning A arms (mash557)
What are you guys doing to your cars to get them so dirty? I just use a spritz of simple Green and wipe 'em off with a paper towel. ;)
Old Dec 6, 2001 | 10:59 PM
kbklt1's Avatar
kbklt1
You mean they arent chrome from the factory???
:jester
Old Dec 6, 2001 | 11:47 PM
snaketr's Avatar
snaketr
Default Re: Cleaning A arms (kbklt1)
go to napa and get some alum-a-brite or an aluminum cleaner. Do not use the stuff that says it is safe on clear coat, you want the etching cleaner. Spray it on and hose it off and the arms will look brand new.
Old Dec 7, 2001 | 02:34 AM
Radio Joe's Avatar
Radio Joe
I used a bunch of "scrubby" pads and WD-40..Another member suggested this and it worked great for me!
Old Dec 7, 2001 | 02:41 AM
Kale's Avatar
Kale
you people are so complicated
quick squirt of castrol
wipe
quick wipe on of Flitz
wipe off
look like chrome.
Old Dec 7, 2001 | 03:43 AM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Here are some pics from my drivers side front.
Mothers aluminum and some small sandpaper work. Cleaned with any grease cleaner and wiped with some windex.
http://www.corvetteforum.net/c4/jeffvette//a-arm.jpg
http://www.corvetteforum.net/c4/jeffvette//im000676.jpg
Old Dec 7, 2001 | 03:52 PM
rubyred93's Avatar
rubyred93
Default Re: Cleaning A arms (Jeffvette)
In essence, it sounds as though those that use product's like Mother's, etc. are actually polishing the A Arms. Were they polished from the factory? I thought for sure that they were clear coated. ?? What do you think?
Old Dec 7, 2001 | 03:57 PM
black86targa's Avatar
black86targa
Default Re: Cleaning A arms (rubyred93)
I just got mine and spent 1/2 a day cleaning all the front, suspension, engine compt. I soaked it all down cold with Greased Lighting, strong mix, hosed it off. then scraped off any big chunks with putty knife and wire brush, then finished spraying it in a self serve car wash. The previous owners never cleaned anything for 100,000 miles. Now it will just get a spray off every month or two.
Old Dec 7, 2001 | 04:11 PM
65Z01's Avatar
65Z01
I like carb cleaner if greasy, followed by Scotch Brite pad treatment and finally Eagle's Never Dull.
If you want to brush Al, use a copper or brass brush not steel.
Also, I'd be very careful about using water near the front area of that '93!!
Old Dec 7, 2001 | 04:27 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
Default Re: Cleaning A arms (65Z01)
The best cleaner i have ever used is Castrol Cleaner Degreaser, twice a year I take the wheels off of the vette and my M3 and clean everything with it. With 50/50 solution and a mild brush it will clean it to like new..
after 50k on the M3 the wheels wells are spotless..
on the vette I painted and clearcoated the rear suspension and use just soap and water , but on the front i use the castrol and everything looks as new.
try it, you will be very suprised(just keep it off the paint, I think it is harsh as it burns the hell out of your hands if you have any cuts)
Old Dec 7, 2001 | 06:39 PM
SunCr's Avatar
SunCr
I use the metal polish wadding. I think Eagle One, but there are other brands.
To Cleaning A arms
