Need Part Number O2 sensor
Old Mar 3, 2008 | 05:45 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Need Part Number O2 sensor
The tech tips have an autozone part number 13190 listed for the heated O2 sensor. None of the Autozones around here have them and are having a hard time getting them
Anyone know the Bosh number so I can call Napa, Pep Boys, or someone else?
Old Mar 3, 2008 | 06:04 PM
MK 82's Avatar
MK 82
Google is easy to use. Try it.
http://www.ls1tech.com/forums/showpo...3&postcount=20
Old Mar 3, 2008 | 09:20 PM
jsup's Avatar
jsup
Originally Posted by MK 82
That lists all LT and LS parts. Are they the same?
Will ANY three wire O2 sensor work?
Here's a link to Rock Auto, will the first one work?
http://www.rockauto.com/catalog/rafr...3&a=FR23-13913
Will any of them work?
It's hard to tell the wire color. I suspect that the black wire is ground, is the white power or to the ECU?
I came up with Bosch 13913 as a "universal 3 wire".
I don't want to fk up my ECU becuase I got the wrong sensor, and I don't want the car to run like crap for the same reason.
Old Mar 3, 2008 | 09:25 PM
racebum's Avatar
racebum
13190 is the bosch number, go to ebay and type bosch 13190 you will find a couple sellers offering them for under 40 bucks. just installed this same sensor myself, much better cold start driving with long tubes. Actually, here's where i bought mine.
http://cgi.ebay.com/ebaymotors/Bosch...spagenameZWD1V
Old Mar 3, 2008 | 09:29 PM
jsup's Avatar
jsup
Thanks, I'm going to pick it up locally. The couple bucks doesn't mean as much to me as getting this done and over with.
The application is for Chrysler, will the ECU feed be the same regardless of application of sensor? Is it just the physical connector that is different?
Old Mar 3, 2008 | 09:30 PM
c4cruiser's Avatar
c4cruiser
The 13190 is a Bosch part number.
If the 13193 is a universal heated O2 sensor, there should be three wires; two of one color (probably white) and one black. The two wires of the same color are power and ground (doesn't matter which). The black or single color is the connection to the wire harness conector.
Old Mar 3, 2008 | 09:35 PM
jsup's Avatar
jsup
See question above. Do all ECUs see the O2 sensor the same? Is it just an open and closed switch?
Old Mar 3, 2008 | 09:46 PM
MK 82's Avatar
MK 82
http://www.howstuffworks.com/question257.htm
Google is your friend.
Old Mar 3, 2008 | 09:52 PM
jsup's Avatar
jsup
From the link:
The oxygen sensor is positioned in the exhaust pipe and can detect rich and lean mixtures. The mechanism in most sensors involves a chemical reaction that generates a voltage (see the patents below for details). The engine's computer looks at the voltage to determine if the mixture is rich or lean, and adjusts the amount of fuel entering the engine accordingly.
Does every ECU look for the same voltages or does the voltage vary from sensor to sensor, application to application.?
The article is moot on the point.
Actually if you look at sensors there are some that specify before cat, after cat, in manifold, which leads me to believe that they all send a different signal.
Old Mar 3, 2008 | 09:56 PM
Pete K's Avatar
Pete K
The sensor from the link I provided works perfectly. You may want to reconsider buying it from e-bay, or another source.
I have done this conversion to at least 5 vettes with perfect results.
Old Mar 3, 2008 | 10:00 PM
MK 82's Avatar
MK 82
Most sensors voltage output is between 0 and 1.1 volts.
Old Mar 3, 2008 | 10:01 PM
jsup's Avatar
jsup
Thanks, this is my first FI project. I'm learning. That's 1/2 the point of doing this.
Old Mar 3, 2008 | 10:02 PM
jsup's Avatar
jsup
I'm going to pick it up locally, which is why I wanted the Bosch number, the Autozone number doesn't help. Thanks.
Old Mar 3, 2008 | 10:35 PM
racebum's Avatar
racebum
the 13190 uses a 3 pin harness, you simply cut the head off of your 1 wire, solder on a new wire going to 1 of the pins of a new pig tail. the twin white wires are led to switched power and ground. our local NAPA had the other end of this 3 pin connector for $8. I also used the fat red wire that is by the distributor for 12v and ran a ground to the - battery terminal since it's actually pretty close. whole job with soldering and probing took around an hour. Also, nothing to worry about with the "will it work issues" I'm personally driving on this sensor in my 1990, works like a charm. Did i mention my heater core died on the first test drive
Old Mar 3, 2008 | 10:42 PM
jsup's Avatar
jsup
Thanks. That's what I needed to know. I appreciate it.
What I am going to do is cut the connector off my stock replacement O2 sensor that I have now. Put that on the single wire.
I'm going to get a 2 pin connector and connect the power with that. The ground is right there, finding a switched power lead should be easy enough.
Old Mar 4, 2008 | 03:16 AM
racebum's Avatar
racebum
i thought about doing the same thing you just mentioned since i had a 2 pin weatherpack connector laying around. The only reason i didn't is because of the cost of the right 3 pin and the fact it really never is going back to a 1 wire so why preserve it.
Old Mar 4, 2008 | 08:03 PM
jsup's Avatar
jsup
Thanks man, almost done. I did a pretty dam good job too if I do say so myself. $43 at AutoZone. I used my AZ card and hit the mark where I got $20 off. So it cost me $23. Good deal.
I got the 13190 with the 3 pin connector and the female side of the connector, that I had to buy separately. I made up the connector with pins that I crimped, then soldered. One wire went to ground, the other went to the O2 sensor, the last I just have to find a good switched connection.
I used the ground that came off the bell housing, where the rest of the grounds were attached. I took off the nut, put a ring connector with shrink sleeve on the wire coming off the connector, and put the ring on the nut with the rest of the grounds.
I used the old wire off the old O2 sensor, connected it to the new connector, and then connected it back to the OEM connection.
I came up the back of the firewall with the wire, I just have to find a switched connection. I'm thinking off the wiper motor. I have to test the connection, or look at the FSM to see if the switched power is there.
Since most of the electrical work I do is on my boat, all the parts, connections I use are marine grade materials. So it's even better than automotive solutions.
Old Mar 4, 2008 | 09:07 PM
racebum's Avatar
racebum
I used that big red wire on the ignition circut. one of the pink wires from my MSD 6al is going there so i tapped it with a 2 pin and ran one of the leads to the 02. I'm not sure if the wiper is power with key or not. i know where i went is and the fuel pump relay is another popular spot.
To Need Part Number O2 sensor
