How do I use Seafoam engine cleaner?
Old Dec 6, 2001 | 05:57 PM
Kale's Avatar
Kale
Default How do I use Seafoam engine cleaner?
I tried to follow the directions. FUEL INJECTED VEHICLE: POUR 1/3 INTO VACUUM OR PCV
ok, so i pop the vacuum off.. car stumbles.. i start pouring.. suddenly it VOMITS the seafom all over the place and dies.
How do I get it in there?
Also, it tells me to "flood" or "stall" the car once its in. How do I "flood/stall" an automatic fuel injected vehicle? Pull the maf?
Old Dec 6, 2001 | 07:14 PM
Kale's Avatar
Kale
Default Re: How do I use Seafoam engine cleaner? (Smash)
bounce
Old Dec 6, 2001 | 07:17 PM
TIMSPEED's Avatar
TIMSPEED
Pull the fuel pump fuse, duh. It will then JUST suck in the seafoam, then try to start twice, or so. Until it WILL NOT START. Then, it'll have used all the seafoam as fuel, and voila. Put the fuel pump fuse back on, start it up and let it run for a minute or so, then kinda rev it a bit, in order to "blow it out". Take it to 2k, then 3k, then MAYBE 4k. I did that to the pickup a while back. Cleaned the motor pretty good.
P.S. - What vacuum line did you use. I would maybe use the one that connects to the brake booster. It would seem to inject the stuff into the engine the best.
[Modified by TIMSPEED, 5:19 PM 12/6/2001]
Old Dec 6, 2001 | 07:22 PM
Kale's Avatar
Kale
Default Re: How do I use Seafoam engine cleaner? (TIMSPEED)
off the pcv.. hey, is the tall blonde skinny girl with stoner eyeliner your cousin?
Old Dec 6, 2001 | 07:23 PM
TIMSPEED's Avatar
TIMSPEED
Who are you talking about Brian?
P.S. - PCV = NO GOOD. Use the vacuum from brake line booster. I think anyway. That was the biggest vacuum port on my 85's intake at least. I know putting them into the valve covers will do nothing, because it will just get on the rocker arms. The point is to get them into the combustion chambers, to stick to all the crud, then blow it out.
[Modified by TIMSPEED, 5:25 PM 12/6/2001]
Old Dec 6, 2001 | 07:41 PM
Kale's Avatar
Kale
The girl at Riebes.
Old Dec 6, 2001 | 09:39 PM
olephart's Avatar
olephart
I used the spray can of GM TEC - about the same as Seafoam. Held about 1200 rpm and sprayed it in the throttle body then shut off for a few hours. Then drive hard to blow the crap out. Worked good.
Old Dec 6, 2001 | 10:56 PM
Kale's Avatar
Kale
Default Re: How do I use Seafoam engine cleaner? (olephart)
I poured it in and the right side of my engine started smoking like crazy. WTF??
Maybe the EGR pipe is loose?
Old Dec 6, 2001 | 11:26 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
its supposed to smoke, thats what seafoam does, but it cleans like crazy
Old Dec 6, 2001 | 11:31 PM
Jedi404's Avatar
Jedi404
Default Re: How do I use Seafoam engine cleaner? (My 95)
Smash, whats up man? I was down in the Heights tonight checking out cd players. I couldn't get one because I have a Bose system, so I just got a RF Changer up at Audio Express.
Old Dec 6, 2001 | 11:44 PM
Kale's Avatar
Kale
Default Re: How do I use Seafoam engine cleaner? (Jedi404)
I *HAD* a bose system. Not anymore!
BTW dont go to auto radio stereo
the yare con artists
Old Dec 6, 2001 | 11:45 PM
Kale's Avatar
Kale
Not the engine.. the exhaust should!! but the engine does!
Old Dec 7, 2001 | 08:08 PM
olephart's Avatar
olephart
It's great for finding leaks. If the exaust system is leaking in front of the cats, its probably messing up your fuel/air ratios.
Old Dec 7, 2001 | 08:46 PM
Kale's Avatar
Kale
Which could be why I'm not passing smog?
Old Dec 7, 2001 | 10:07 PM
JonM's Avatar
JonM
There was another post here today about Seafoam. The guy used the vacuum off the break booster. Kept the throddle up to 1200 RPM' s.
Old Dec 7, 2001 | 10:18 PM
Juliet's Avatar
Juliet
Default Re: How do I use Seafoam engine cleaner? (JonM)
Do you need to change the plugs after using the cleaner? I know that the Berryman's B12 Chemtool cleaner fouls plugs - cleans the carbon out great, but requires a plug change afterwards. ;) ~Juliet
Old Dec 8, 2001 | 03:25 PM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: How do I use Seafoam engine cleaner? (Juliet)
It seems that you would want to do this prior to changing plugs.
**Warning: your O2 sensors and/or spark plugs may get moderately dirtier if this is the first time you've cleaned your intake manifold and/or throttle body. You may wish to do this for the first time right before you install new ones.
I read this here: http://w3.one.net/~roz/cars/z28/seafoam.html
Where do you get this stuff? :confused:
-John
[Modified by War Machine, 1:26 PM 12/8/2001]
Old Dec 8, 2001 | 04:08 PM
Wheelman's Avatar
Wheelman
Default Re: How do I use Seafoam engine cleaner? (War Machine)
napa is a national autoparts chain
if one is not in your area, try other chain autopart stores.
Old Dec 8, 2001 | 07:55 PM
War Machine
Default Re: How do I use Seafoam engine cleaner? (C4Fetish)
Thanks C4Fetish ! That explains it. I haven't been to napa in a long time. I have one 25 min away. :cool: :cheers:
To How do I use Seafoam engine cleaner?
