Test Springs
Old Mar 4, 2008 | 02:55 PM
MK 82's Avatar
MK 82
Default Test Springs
Anyone know where to find the weak springs used with an adjustable pushrod when you are finding the right length pushrod?
Old Mar 4, 2008 | 03:10 PM
F1Fan's Avatar
F1Fan
I don't believe you need weak springs for this. I just measured mine with my aftermarket springs on.
Edit: Here's a good article on doing this, I also used their "Hi Tech" brand adjustable pushrod.
http://www.compcams.com/Technical/FAQ/FAQPushrods.asp
Old Mar 4, 2008 | 03:25 PM
MK 82's Avatar
MK 82
I need them to keep the lifter from compressing while i rotate the engine to check the pattern.
Old Mar 4, 2008 | 04:22 PM
CFI-EFI's Avatar
CFI-EFI
Use a solid lifter. As far as a spring goes, have you scrounged around in a hardware store/home center?
RACE ON!!!
Old Mar 4, 2008 | 06:40 PM
MK 82's Avatar
MK 82
A solid lifter is an option as long as it is the same height as the Hyd one. I haven't tried the hardware store route.
Old Mar 4, 2008 | 07:26 PM
MK 82's Avatar
MK 82
Found Them!!
http://store.summitracing.com/partde...5&autoview=sku
To Test Springs
