dash lights
Old Jun 9, 2009 | 01:51 AM
freedog81's Avatar
freedog81
sorry about that I took the ohm meter and checked all of the fuses first hoping it was a simple fix like the other one but I had no such luck.
I think it is the switch though because sometimes it works and if i hit a bump the dash will go black and another bump and they work again? It is really strange.
Old May 14, 2011 | 08:03 PM
dtk's Avatar
dtk
1st Gear
Default 90 Vette - headlamp switch
I'm commenting on your 2 year old post, which was commenting on an even older post.
Did you ever solve your problem?I've got the same issue: No dash lights at night unless I apply pressure to the dimmer switch. Am wondering whether I have to replace the whole headlamp switch assembly or can just order a new dimmer switch. Quite a difference in $$$.
