will increased fuel pressure increase HP?
-- Joe
The PE mode flag is bit 7 in the ram byte at L0038 in $32 and $32B and L0039 in $6E.
It is not normally present in the serial data, but could be with a simple code change to output this byte in place of something else in the data stream.
I think I've just found something else to modify...cool.
The BLM learn control flag (Bit 1 in the Air Fuel Mode word #2 L0044 may also be useful as a PE indicator). I see it now, the BLM learn enable flag is cleared if the Target AFR is not equal to stoich AFR. If PE results in a non-stoich Target AFR, which is typical, the BLM learn flag will be cleared.
On the contrary, if the PE tables are changed to 0% AFR change, then PE mode won't clear the BLM learn flag.
It is a good indicator of PE mode, but not perfect since open loop will likely command a non-stoich AFR also and have the same effect on the flag. Therefore it could indicate either PE mode "or" open loop. In addition, coolant temp and load also play a role in setting the BLM learn enable flag.
I'll try and compare these flags once I have them both in the serial data, but I have a good understanding now of what to expect.
Is it a personal attack to plead with you to stop posting falsehoods and misinformation? I just hate to see people who are trying to learn, be so mislead. I don't know how else to do it. Sorry.
RACE ON!!!
You, yourself took it to about as personal (and inappropriate) a level as I have ever seen on this forum.You have at least three people here telling you why you were erroneous in your posting about gas laws, reletive to fuel pumping, yet you come across as being Holier than thou. Strange behavior.
On the other thread you mentioned, I responded to CFI with the same type of posting he is doing - and you are right, that was 100% wrong of me, which is why I edited the posts. (which were then deleted). It was my mistake becoming like him, even if it was temporary and it won't happen again.
-- Joe
but whatever the blm/int was prior to entering PE mode will adjust to the injector PW while in PE. I've verrified the closed loop flag on both datamaster, and my snap-on scanner.
In true "open loop" there is zero correction, and the injector pw is calculated based on the main fuel table.
The statements made previously were "At WOT the engine does not use the O2 sensor to correct for air/fuel ratio.", thus implying the car would run rich under "wot". This is not entirely true. As long as the car has entered closed loop, it has learned the fuel trim offsets and will apply those corrections while in PE assuming it was able to correct in closed loop. (within the BLM boundries).
Obviously this went over someones head, because it was easier for them to say "Your stupid! You don't know what closed loop is" rather than read and understand what I was explaining..
-- Joe
The closed loop flag can remain active during PE and the appropriate fuel trim will still be applied. Typically the cell 15 blm value for the MAF masks.
I would consider PE within closed loop as a "compensated" form of open loop control, since the long term fuel trim is compensating for a previous rich/lean error in cell 15.
This will accomodate small changes in fuel pressure or injector size. Of course, if you increase it enough to peg the blm at 108, the extra fuel pressure will result in extra enrichment even in closed loop.
This would only really make sense if the MAF was pegged and normal (12.0-12.8ish) PE targets are resulting in a too lean mixture and if it was your only available means of tuning.
Today we have better options with readily available custom tuning.
-- Joe
RACE ON!!!
Is "Active 02 feedback will not change BLM/INT" not the definition of open loop? Closed loop is the ECM altering the pulse width of the injectors based on readings from the O2(s). The O2(s) can't even accurately read the A/F ratios at PE, let alone have the ECM adjust to them.
And in the open loop of PE, in your own words, "Active 02 feedback will not change BLM/INT". Also in the PE ""open loop" there is zero correction". "Active O2 feedback" changing the pulse width to alter the A/F ratio is the essence of "closed loop. The open loop of PE operation also has "zero correction", the same correction as the open loop of an engine not yet warmed up.
First, I never called you or anyone else stupid. If getting caught saying that open loop is closed loop, makes you feel stupid, then, if the shoe fits... That is YOUR reaction to being caught, not something I called you. It did not go over my head, that in the PE mode, the fuel mixture may be based on the last previous feed back from the O2, before entering PE and leaving closed loop. The point is moot. The point is that the pulse widths are NOT changed in PE mode, based on incoming O2 readings. The fact remains that closed loop IS left when WOT is activated and the PE mode invoked. In other words, the ECM does NOT continue to react to O2 readings while in the PE mode. That, of course, makes the PE mode, "open loop". Q.E.D.
RACE ON!!!
-- Joe
-- Joe
RACE ON!!!
RACE ON!!!
You failed to read my points, you would rather twist it to make it sound like something else - than argue that. You are not helping anyone here.
Thats fine. For a guy with an crossfire C4 and a beat up truck, you seem to think your quite the expert on *everything*. But then again, spending 10 years working a parts counter would probably make you feel that way.
-- Joe
-- Joe
RACE ON!!!
Anesthes is talking about GM's specific implementation. It may be that GM sets the "closed loop" status bit, or that it uses fields in PE that it doesn't use in other open loop operation. This is an implementation (an imperfect one) of a general concept.
So within the context of each argument, both appear to be correct (to uneducated me). You just have different contexts. Why not just acknowledge that and move on.
FUEL PRESSURE AND VOLUME
The relationship of pressure to volume is inversely proportional. That is, as
pressure increases the volume will decrease, everything else being equal. A
certain amount of fuel pressure is always required to maintain engine performance
by assuring that fuel is available on demand. Also, other factors
and conditions must be taken into account such as acceleration G-forces and
friction within the fuel system itself. At the same time,however, an adequate
fuel volume is needed to ensure that the proper amount of fuel can always
flow to the engine, especially during peak demand situations. A basic understanding
of this critical pressure/volume relationship is needed when designing
the proper fuel supply system for your vehicle.
Now this does dot say the pump volume decreases but , I think, it is talking about the fuel system volume. I really hate to stir the pot but I think Joe got more than his share of flames. Later! Frank
-Tom
I don't know the answer to this. my "facts" were based on release notes from the pump manufacturers, which is why I posted the walbro table.
I was dead serious about what I said regarding finding me a pump whose volume won't decrease with pressure increase. I'm using an FMU and will see pressure increase at a ratio of 8:1 with boost. if you look at the walbro table, I'll be getting the same volume with max boost as at idle.
-- Joe
RACE ON!!!
