Annoying fuel pump noise
Old Mar 5, 2008 | 02:10 PM
Pizzano's Avatar
Pizzano
Default Annoying fuel pump noise
Hello again, does anyone else running a Procharged P600B with the added fuel pump installed in back of the rear license plate also have a annoying whinny noise, especially at idle, is there a way to remount it with some isolaters or something to cut down the noise.
Thanx for any help
Old Mar 5, 2008 | 04:01 PM
mgolden's Avatar
mgolden
No but if there's room I wouldn't see why you couldn't use something like this:
http://cgi.ebay.com/Rubber-foot-vibr...QQcmdZViewItem
Wander around your local hardware store and you might be able to find something similar. I used something similar to that on the electric fuel pump on my old car and it helped a lot.
Good luck, let us know how it turns out!
Old Mar 5, 2008 | 04:12 PM
Pizzano's Avatar
Pizzano
no room for anything like that, if you have the procharger setup on a L98 you will know what I mean, thanx
Old Mar 5, 2008 | 05:16 PM
silver86's Avatar
silver86
What kind of pump are you running? I'm running a Walbro 255 in-line with rubber isolation sleeve. I'm not sure what the Procharger setup runs.
Is it a vibration issue, or is it internal pump noise?
Old Mar 5, 2008 | 06:23 PM
mgolden's Avatar
mgolden
Is the pump mounted with a U-shaped bracket around the pump and then bolted to the body? If so a little rubber gasket material between the pump and the bracket would probably help too.
Got a picture of the setup?
Old Mar 5, 2008 | 08:37 PM
Brand-X's Avatar
Brand-X
Consider yourself lucky if the fuel pump is louder than the P600B! lol Try rubber mounting an inline Walbro. They're pretty quite. Good luck!
Old Mar 6, 2008 | 12:35 AM
Pizzano's Avatar
Pizzano
Really dont know the brand , it is the pump that came with the package, I will investigate a little further. thanx
Old Mar 6, 2008 | 02:59 AM
Mo_Bandy's Avatar
Mo_Bandy
I mounted mine with the pump wrapped with soft rubber i only hear it on starting the engine when it pressiurizes the fuel system...
Mo
Old Mar 6, 2008 | 03:50 PM
BlowerWorks's Avatar
BlowerWorks
Supporting Vendor
Hey Pizzano,
The Vortech & ProCharger in-lines are Airtex: very noisy! Replace with the Walbro GSL-392 (I sell) and I promise you won't hear except for key on like 'MO' above said. Hi MO !!!
Best regards,
Greg
Old Mar 6, 2008 | 04:12 PM
Pizzano's Avatar
Pizzano
Originally Posted by BlowerWorks
Hey Pizzano,
Best regards,
Greg
Whats the price of that pump, and to answer the other post, it is wrapped in a rubber cup type insulator.
Can I just replace the Walbro out or do I need to change the wiring also, there is a relay mounted back there also.
Thanx
Old Mar 7, 2008 | 01:00 AM
Mo_Bandy's Avatar
Mo_Bandy
It should wire right up with no problem...
Greg's kit is very good... ( Hi Greg)
Mo
Old Mar 7, 2008 | 07:10 AM
Pizzano's Avatar
Pizzano
Nice website Mo , love that stroker
Keep Jamming
Long live the Blues
Old Mar 8, 2008 | 09:38 AM
anesthes's Avatar
anesthes
Hey Pizzano,
Best regards,
Greg
How is your pricing on walbro? I'm running a 8:1 fmu as well. I don't want to run an inline pump, i'd rather swap the in-tank for a 255 high pressure walbro. I normally buy pumps from APE.
-- Joe
Old Mar 10, 2008 | 01:06 PM
BlowerWorks
Supporting Vendor
Hey Guys,
The Walbro GSL-392 pump is $140.00. You need the install kit because it has the M10 barbed hose fittings - $15.00. That's all you need if you already have the Airtex in-line.
Joe, I really suggest you add the in-line to your GSS-340M and not try to go with in-tank only - it's so much better with 2 pumps in-series as I have explained why SO MANY times before on this forum. If you want to use the in-tank 340 by itself and are using an FMU then epoxy close the relief valve - but you will shorten its' life at the much higher currents it will draw.
If anybody interested further please contact me directly at: "greg@blowerworks.net". I do not sign in all that often.
Regards, Greg
To Annoying fuel pump noise
