raidator tank
Old Mar 5, 2008 | 10:37 PM
cvblack95's Avatar
cvblack95
Cruising
Default raidator tank
Has anyone ever had to replace the coolant tank on a c-4 vette?? Mine is leaking where the filler neck goes into the tank.After i replace it will I need to blead the air out of the system?I know there is a valve or plug by the water pump to blead out the air,but when do you need to blead out the air and how do you know you need to.Thanks for any help
cvblack95
Old Mar 6, 2008 | 12:10 AM
staugur's Avatar
staugur
Are you referring to the expansion tank? The one down in the passenger side wheel well.If you are,when you change it, there should be no need to BLEED anything.
Old Mar 6, 2008 | 08:35 AM
aminnich's Avatar
aminnich
I answered your question in your other post (parts section).
Old Mar 7, 2008 | 11:16 PM
cvblack95's Avatar
cvblack95
Cruising
Default raidator tank leak
AMININNICH:Sorry for being in the wrong section.first time on the forum as a nember.
Anyway are you saying that if I blead the system I may not have to replace the resvoir tank??Or that after I replace the tank then I will have to blead the system??
Thanks for all of your help
Old Mar 7, 2008 | 11:19 PM
cvblack95's Avatar
cvblack95
Cruising
No I am talking about the radiator fill tank where the radiator cap is.
Old Mar 7, 2008 | 11:24 PM
cvblack95's Avatar
cvblack95
Cruising
I did not know that I could answer like this.Sorry I was in the wrong place.First time on the forum as a member.Are you saying that if I blead the system that I may not have to replace the resvior?? Or that I will have to blead the system after I replace the resvior?
Thanks for your help.
Bob
Old Mar 8, 2008 | 07:51 AM
aminnich's Avatar
aminnich
Bob
I mean bleed the system after the repair and when refilling the coolant.
To raidator tank
