Zz383 Goin In
Old Mar 6, 2008 | 12:43 AM
CHISGT's Avatar
CHISGT
Default Zz383 Goin In
HERE ARE SOME PICTURES OF THE MOTOR. SHOULD GO IN TOMORROW.
Old Mar 6, 2008 | 01:44 AM
cv67's Avatar
cv67
St. Jude Donor '05
Sweet! Should be a boatload of fun, hope you bought stock in Goodyear.
Old Mar 6, 2008 | 07:12 AM
TA's Avatar
TA
Looking good, can't wait to hear some numbers for that baby
Old Mar 6, 2008 | 10:49 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Is that a FIRST intake? Looks good
Good luck, we'll need to see some more pic's.
Old Mar 6, 2008 | 11:02 AM
cajun86's Avatar
cajun86
What injection system are you using ? Do you know if the ZZ383 is compatible with the Super Ram intake ?
Old Mar 6, 2008 | 11:26 AM
Demonic85's Avatar
Demonic85
You can use any SBC Gen 1 intake you want, but HP, torque, and the rpm range will vary.
Old Mar 7, 2008 | 12:28 PM
87FIREREDRAGTOP's Avatar
87FIREREDRAGTOP
What balancer and timing cover are you using? I used the factory L98's and am having isues. The Motor looks great.
Old Mar 7, 2008 | 10:58 PM
CHISGT's Avatar
CHISGT
I used the balancer that came on the ZZ383 motor along with the timing cover. I had to grind the top bolt of the timing cover pretty far. Also a small bit of grinding on the edelbrock aluminum water pump that I was told would fit without any issues (by Edelbrock tech line)
Old Mar 7, 2008 | 11:03 PM
CHISGT's Avatar
CHISGT
Motor went in last night. I hope to have it running and on the street by next weekend. By the way this is the First Fuel Injection Unit,More pictures as we progess.
To Zz383 Goin In
