Still draining!!!!!!!
i took it to 2 shops that i trust and 1 of them had it for 2 days and i jsut got it back from being at the other one for 3 days. they both pretty much tore down the entire car tryin to find my draw but could not find it.
the guy i get my vette parts from locally said that 84's were known to have some kind of problem in the gauge cluster that would cause a drain. is that true?
If your leakage isn't from a fused circuit, then it has to be from a circuit with a fusible link, or a circuit breaker.
It IS just that simple. Tell those shops to give you your money back and then FSM in hand, attack it yourself.
RACE ON!!!
Good luck, Paul
I recommend you do these tests yourself because the two shops you tried appear to not know crap about electrics.
At night, check for underhood lights, door map lights, vanity mirror lights, center console light, cigarette lighter light, spare tire light. Do you have any aftermarket electronic items, theft alarm, CB radio, radar detector, am-fm radio, cd player, audio amplifier, satellite receiver, gps receiver, car phone? Unplug them while watching your ammeter. Feel your seat adjuster motors after the battery has been connected for awhile, are they warm? Stuck seat adjuster switch is a common fault. Your 84 car gets its power to all accessories through a wire that is connected to the large cable on your starter motor. Remove the neg batt cable (for safety) and remove the smaller wire on the starter, then have someone touch the neg cable to the neg battery post and you measure the current from the starter terminal (that the large cable is still connected to) to the smaller wire. My bet is you will measure 400 milliamps after the courtesy lights time out. If so, you have leakage current flowing through one or more fuses (you claim pulling fuses doesn't reduce leakage current right?), OR through one or more circuit breakers or through fusible links (that is every circuit in your car except the starter motor). I don't know if the circuit breakers are unpluggable, if they are, watch the leakage current while you unplug the circuit breakers or remove 12v power to them. I don't have an 84 circuit diagram, but there are circuits with fuseable links (8 on my 87) and you need to find those and disconnect them one at a time while watching the ammeter. Except for the starter motor, that covers every circuit in your vette and somewhere in this test you have to find the leakage current. If you want to find the leakage current the above procedure is what you MUST do and it is a lot of work. Get busy!
Post in this thread if you have any further questions.
RACE ON!!!
i dont know if this is part of the problem but when they had my door panels off before changing my door locks i did see some stripped wires that werent hooked up to anything.
my stereo guy did tell me that he saw 3 wires under the dash (when he was doin my alram) 1 was constant power and 2 were accessory. he said that one of the accesory wires were staying on. im goin to them 2morrow and i will see if he can show/tell me what he thinks i can do.
what do you think that is?
Then with your DVM set to milliamps, remove one fuse at a time and see if there is a drop in the reading. If not, replace that fuse and move to the next one.
It might be that the guy that installed the alarm messed something up. Unless the alarm is designed or programmed to flash the lights or turn the raio on, that should not be happening.
