Disabeling "Service Engine Soon" Idiot light
Old Mar 7, 2008 | 10:22 PM
dr.leland's Avatar
dr.leland
Navigator
Default Disabeling "Service Engine Soon" Idiot light
This drives me nuts!! How can I kill this thing?? Pull the dash, and pull the light or what?? Also, read on a thread that to increase performance on my 87, that I should reflace air filter with a K&N and cut some slots in the housing,,,any suggestions on how this is done??
Old Mar 7, 2008 | 10:24 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Fix the problem?
Old Mar 7, 2008 | 11:05 PM
Riks40th's Avatar
Riks40th
From: St. Louis, Mo......... 1993 Torch Red w/White Interior...2006-07 Bloomington Gold 2005-ZR1/C4 Gathering, 2001-2012 Funfest
That's kinda what I was thinking. It's coming on for a reason, no?
Old Mar 8, 2008 | 01:52 AM
C4Ownr24's Avatar
C4Ownr24
stick a screwdriver through your instrument cluster glass.
oh, and if your low oil psi light comes on, just stab that one out too. also, if your vehicle begins to overheat, disconnect your temp gauge. get my drift? cars are pretty easy to fix!!!! yay!!!
Old Mar 8, 2008 | 01:56 AM
Pizzano's Avatar
Pizzano
Read your codes and find out what the problem is.
Underneath the dash is the ecm hookup, jump out the upper right two slots (A/B).this grounds the ecm.
the service engine light will flash "12" three times , followed by whatever error codes after that, meaning one flash followed by 2 flashes =12, etc, record the codes and look in your Haynes manual and see what the code means.(example: 4 flashes followed by 3 flashes = code 43).
Hope this helps.
Old Mar 8, 2008 | 02:02 AM
RRT vette's Avatar
RRT vette
The SES light is on because the ECM has detected a fault in the connection, circuit, or component. You will need to pull the codes and see what is wrong.
http://www.obd-codes.com/faq/read-gm...codes-free.php
Old Mar 8, 2008 | 03:50 AM
comp's Avatar
comp
or tape over it
Old Mar 8, 2008 | 03:59 AM
jsup's Avatar
jsup
Originally Posted by comp
or tape over it
If it makes noise, turn the radio up.
Man, I'd hate to be the sucker who buys this car when you're done with it...
Old Mar 8, 2008 | 04:23 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Learn to use the Search function, and include archives, then read and read some more...
Old Mar 8, 2008 | 07:20 AM
ToniH's Avatar
ToniH
I wonder why they call it "idiot light"?
Old Mar 8, 2008 | 07:36 AM
comp's Avatar
comp
Old Mar 8, 2008 | 08:24 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
or tape over it
Bought a few cars like that, and with the bulb pulled out. Got to where I always check to make sure the CE lamp was on when I turned the key on.
Old Mar 8, 2008 | 08:38 AM
WW7's Avatar
WW7
Sometimes this doesn't even help, Ive seen where some people wire the check engine light to one of the other dash lights so that it comes on and goes off with that light. Then it looks like its working normally. WW
Old Mar 8, 2008 | 09:14 AM
MK 82's Avatar
MK 82
Black spray paint!
Old Mar 8, 2008 | 09:15 AM
MK 82's Avatar
MK 82
The car does a bulb test when you turn on the ignition. Your SES light should come on momentarily then.
Old Mar 8, 2008 | 10:38 AM
cv67's Avatar
cv67
St. Jude Donor '05
Pull codes and fix the problem. Trust me you want that display working to tell you when theres a problem otherwise youre going into it blind.
Or just take a hammer to the dash.
Happy motoring.
Old Mar 8, 2008 | 01:23 PM
TA's Avatar
TA
To Disabeling "Service Engine Soon" Idiot light
Old Mar 8, 2008 | 03:13 PM
runner140*'s Avatar
runner140*
As all others said bro, fix the problem. Its easy to pull the codes. Buy a FSM and follow the steps. It may only take the time you spent on your post.
Old Mar 8, 2008 | 03:33 PM
jsup's Avatar
jsup
No response back from the OP? Seems that he didn't get the answers he wanted?
Old Mar 8, 2008 | 06:25 PM
86PACER's Avatar
86PACER
Ground A and B with paper clip, turn key on, and count the flashes as described HERE Write down any trouble code(s)
Now go here and fix the problem(s).
Trouble Codes
