Check Guages Light
Old Mar 9, 2008 | 11:02 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Check Guages Light
All my gauges seem to be working just fine. How can I find out WTF this means?
Thanks.
Old Mar 9, 2008 | 11:07 AM
Tom Piper's Avatar
Tom Piper
Just a thought, I've seen my "Check Gauges" light illuminate because of the fuel level.
Tom Piper
Old Mar 9, 2008 | 11:15 AM
jsup's Avatar
jsup
Tom Piper
Yes. got 3/4 tank. But good catch. Clearly I'm over thinking this as I forgot that.
Old Mar 9, 2008 | 11:20 AM
Tom Piper's Avatar
Tom Piper
[EDIT]
I just noticed in your profile, that you have an L98.
My comments are true for an LT1, I don't know about an L98.
That is why it is best for the original poster to ALWAYS identify the year of the vehicle up front.
Also, the oil pressure switch sender that activates the "Check Gauges" light is electrically totally independent of the analog sender for the oil pressure gauge -- therefore, even if the oil pressure gauge is reading correctly, if the oil pressure switch or wiring is defective, it could turn on the light.
Tom Piper
Old Mar 9, 2008 | 02:08 PM
SunCr's Avatar
SunCr
Maybe the later L98's had a Check Gages Light? I know my '89 doesn't. If so, GM and other automakers usually use this function to alert you to a system problem not otherwise controlled by the ECM/PCM; ie, Body Control Module faults such as A/C, Radio, Air
Bags or any item that relies on this Processor.
Old Mar 9, 2008 | 03:04 PM
MK 82's Avatar
MK 82
On my 96 Check Gauges comes on for:
1. Hi Eng Oil Temp
2. Lo Oil Press
3. Hi Coolant Temp
4. Hi/Lo Batt Voltage
5. Lo Fuel
6. Hi Auto Trans Temp
Old Mar 9, 2008 | 07:21 PM
Vettehappy's Avatar
Vettehappy
1. Hi Eng Oil Temp
2. Lo Oil Press
3. Hi Coolant Temp
5. Lo Fuel
Old Mar 9, 2008 | 10:54 PM
SunCr's Avatar
SunCr
You guys are right - I went back and checked the oldest Service Manual I could find with this Feature - '94 Sonoma - and the Check Gages Light was driven/grounded through a separate Module linked to the Oil Pressure and Temp Gages. Not much on Diagnostics but would assume that if there's nothing wrong with any readout, there's an intermittent short to ground at the light or a bum module. Don't know where I got the Body Module notion unless on those equipped its the Driver rather than a separate part.
To Check Guages Light
