Injectors for 410 CHP
Old Mar 9, 2008 | 06:49 PM
MK 82's Avatar
MK 82
Default Injectors for 410 CHP
What size do I need for an LT4 with 410 CHP?
P.S. Who made stock Lt4 injectors?
Old Mar 9, 2008 | 07:51 PM
STL94LT1's Avatar
STL94LT1
The stock 28# injectors should work just fine.
Old Mar 9, 2008 | 09:06 PM
MK 82's Avatar
MK 82
Mind telling me how you arrived at that conclusion?
Old Mar 9, 2008 | 09:19 PM
FD2BLK's Avatar
FD2BLK
I have ran 28# LT4 injectors on a 360RWHP LT1 (Head and Cam Package) with only a 80%Duty Cycle so there is plenty of room with the stock 28# injectors for well over 400CHP
Old Mar 9, 2008 | 09:21 PM
STL94LT1's Avatar
STL94LT1
410 CHP is what, about 350 to the wheels. My car is running 375 rwhp with the stock 24# LT1 injectors.
Old Mar 9, 2008 | 09:34 PM
MK 82's Avatar
MK 82
Is this via dyno run?
What is the duty cycle at WOT?
What fuel press are you using?
Old Mar 9, 2008 | 09:38 PM
STL94LT1's Avatar
STL94LT1
Yes, this is through a dyno run. At 375 rwhp my duty cycles are pretty high, at 355 rwhp they were ~85%. With my new combination I could probably use a larger injector. At 355 rwhp they were just right.
Currently my fuel pressure is turned all the way up. At 355 rwhp it was ~45 psi.
Old Mar 9, 2008 | 09:48 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Is there a formula to figure this all out?
Old Mar 9, 2008 | 09:59 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Cartek used #30 ford injectors in my car @360 rwhp
Old Mar 9, 2008 | 10:01 PM
MK 82's Avatar
MK 82
I am sure there is and I hope someone will chime in with it. This beats talking about Optis, Fans, and Thermostats.
Old Mar 9, 2008 | 10:07 PM
jsup's Avatar
jsup
I simply don't know enough about FI, and I'm trying to learn.
The most I know is about bank fired, and sequential fired. That's as far as it goes.
Old Mar 9, 2008 | 10:10 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Lloyd Elliott recommends 30# injectors with his 400+ head/cam packages.
www.eportworks.com
Old Mar 9, 2008 | 10:11 PM
jsup's Avatar
jsup
www.eportworks.com
Can you get me another bargain on 30#ers?
I didn't even put 250miles on the ones I purchased from you in July. It was September when I started taking the car apart, so it's been laid up more than running for that time...
Old Mar 9, 2008 | 10:14 PM
Kevin Woods's Avatar
Kevin Woods
Yes.
If I can find it. I'll post the link.
And yes.....the 28LB LT4 injectors should easily feed a 410 CHP set-up.
KW
Old Mar 9, 2008 | 10:15 PM
MK 82's Avatar
MK 82
www.eportworks.com
Yeah I know, I talked to him. It does not compute to me that a 300 CHP with 24# injectors engine could produce 400 CHP without an injector change.
jsup's Avatar
jsup
Originally Posted by Kevin Woods
Yes.
KW
24 is too small?
Old Mar 9, 2008 | 10:16 PM
BADDUCK's Avatar
BADDUCK
Wish I could, I only had 2 sets of those. I would seriously consider upgrading though. I had no idea what you were building when you bought those. You probably didn't either for sure. They should be easy to sell.
To Injectors for 410 CHP
Old Mar 9, 2008 | 10:19 PM
BADDUCK's Avatar
BADDUCK
Do you have 24# or 28# now?
Old Mar 9, 2008 | 10:21 PM
FD2BLK's Avatar
FD2BLK
The reason is your engine becomes more efficient with better cam, heads, headers etc... Just a point of reference Jesse and Cork ran there cars into the 10's with 24# injectors and never had a problem. Now I wouldn't recommend going that far but as long as your car is tuned properly and your injector Duty Cycle stays under 90% you are fine.
Old Mar 9, 2008 | 10:22 PM
jsup's Avatar
jsup
I didn't know I was going to do this at the time. It all came fast.
Those are great injectors.. New they're $700 a set.
Well, if anyone wants to make an offer let me know. They have about 250 miles on them.
