Drive shaft U joint
Old Dec 7, 2001 | 01:57 PM
Barrier's Avatar
Barrier
Default Drive shaft U joint
Since I just replaced the axle U joints 100k miles I wondered (as did Marcho Polo in a recent post), do the driveshaft U joints last longer than the axle ones? It seems to me that they would since there is less movement, although they revolve 3 times as fast? Does anybody have any experience with this. What has to be removed to get to them?
thanks
Barrier
Old Dec 7, 2001 | 03:29 PM
JonM's Avatar
JonM
Default Re: Drive shaft U joint (Barrier)
I needed to replace mine not to long ago. Believe it or not the weld on the shaft let go, just came undone. No hole shot, nothing. I released the clutch and it kept spinning. Strangest thing.
Old Dec 7, 2001 | 05:40 PM
HiRiser's Avatar
HiRiser
Default Re: Drive shaft U joint (JonM)
I did all 6 when I did the halfshafts. It was a waste doing the driveshaft as they looked like new, but it was already apart, oh well. When I thought about the rigid mounting of the driveshaft, you wonder how they could ever wear out.
Old Dec 7, 2001 | 05:46 PM
jmr302's Avatar
jmr302
Yeah, I think I'd agree. The halfshafts see more abuse because the torque of the engine is being multiplied at the differential. I replaced two busted halfshaft U-joints last year. The driveshaft U-joints were just old but not worn out. Replaced them anyway while the exhaust was removed.
Old Dec 8, 2001 | 12:13 AM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Drive shaft U joint (jmr302)
Cheap insurance for $13 a pc. I went with Scorp's (as well as many others)advice and went with Spicer's non-greasable u-joints. Big beefy SOB's.
Here is the site http://www.FORTWAYNECLUTCH.com . They balanced the shaft as well.
Matt
[Modified by 6spd.89, 8:16 PM 12/7/2001]
Old Dec 8, 2001 | 01:16 AM
Eric Fraser's Avatar
Eric Fraser
The driveshaft ones definitely last longer. At 166k+ I have changed the axle shaft U-joints twice and I am still on the original drive shaft ones.
thanks
Barrier
To Drive shaft U joint
