Trick Flow injectors
Old Mar 9, 2008 | 10:31 PM
Kool88vette's Avatar
Kool88vette
Default Trick Flow injectors
I noticed these injectors for sale at summitracing.com There has been a lot of arguing about injectors lately. I know, sorry guys. I'm always at fault.
I noticed these stainless steel injectors by Trick Flow. Now there is a name I know. Summit racing has them. Just wanted to let you know there are alternatives to rebuilts. They are $299.00 for a set of 8. I'm thinking about sending my AC Delco Lucas injectors back and buying them. I just got the AC Delcos yesterday from Eckler's. They were like $650.00 for the set. The Trick Flows have a 90 day warranty. They come in different sizes. Anybody use them?
http://store.summitracing.com/partde...483+4294782211
Old Mar 9, 2008 | 10:38 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
They are probably Accels!
Old Mar 9, 2008 | 10:40 PM
Kool88vette
Are the Accels stainless steel?
Old Mar 9, 2008 | 10:49 PM
STL94LT1's Avatar
STL94LT1
The Summit brand and Trickflow injectors look like Accels. When I upgrade I'll be using Racetronix. They are ~$300/shipped.
Just checked, the Racetronix injectors are Delphi/Lucas.
http://www.racetronix.com/
Old Mar 9, 2008 | 10:52 PM
Kool88vette
It looks like they are different. Very close but different.
Here is the info. Accel on top Trick Flow on bottom.
Brand
ACCEL
Trick Flow Specialties
Product Line
ACCEL Fuel Injectors
Trick Flow TFX (TM) Fuel Injectors
Part #
ACC-150824
TFS-89024
Price
$279.95
$299.95
Description
Fuel Injectors, 24 lbs./ hr., 14.4 Ohms Impedance, 12 Volt, Ford/ GM/ Lincoln/ Mercury, Set of 8
Fuel Injectors, TFX, 24 lbs./ hr., 12 V Saturated Circuit Driver, Universal, Set of 8
Driver Type
12 V saturated circuit
Fuel Rail O-Ring Outside Diameter (in)
0.574 in.
0.590 in.
Injector Advertised Flow Rate (cc/min)
255.0cc/min
Injector Advertised Flow Rate (lbs/hr)
24 lbs./hr.
24 lbs./hr.
Injector Impedance
14.4 ohms
14.5 ohms
Injector Plug Style
Bosch/Amp-style
Bosch/Amp-style
Manifold O-Ring Outside Diameter (in)
0.573 in.
0.590 in.
Notes
See application notes.
O-Rings Included
Yes
Yes
0.943 in.
0.971 in.
Overall Height (in)
2.880 in.
2.830 in.
Quantity
Sold as a set of 8.
Sold as a set of 8.
Seat to Seat Height (in)
2.270 in.
2.153 in.
Wiring Harness Included
No
No
Old Mar 9, 2008 | 11:00 PM
Kool88vette
I like them. Got my Walbro fuel pump from them. Didn't know they sold injectors. Are they new or rebuilts. Seems too cheap for new. I checked out new Lucas and they were like $88.00 each
Old Mar 9, 2008 | 11:17 PM
STL94LT1's Avatar
STL94LT1
Almost certain they are new.
Old Mar 9, 2008 | 11:33 PM
Kool88vette
Why not call them before you order. I looked at the ad it doesn't say if they are new or rebuilt.
Old Mar 10, 2008 | 12:31 AM
Kool88vette
I did a little searching and found this. Looks like Trick Flow introduced their line of injectors in Febuary, 2008. I already decided to send back my Lucas injectors to Eckler's and buy the Trick Flow. I ordered the Trick Flows through Summitracing.com. The total cost was $311.00. Here's an article I found on the internet.
Trick Flow TFX Fuel InjectorsPublish date: Jan 24, 2008
E-mail | Print | Save | License
Click here for copyright permissions!
LOS ANGELES - Trick Flow Specialties TFX Fuel Injectors deliver better fuel atomization, high operating efficiency, and quieter performance than other aftermarket fuel injectors. The injectors are part of Trick Flow's new line of TFX Fuel System Products, which includes fuel filters, fuel pumps, fuel regulators, fuel fittings and hose, and nitrous systems and accessories.
TFX Fuel Injectors feature disc-type fuel control valves and improved nozzles to atomize fuel better. Low magnetic stainless steel injector bodies prevent corrosion from underhood contaminants and seal the injectors from moisture and contamination. The injectors have EV1-style wiring connectors, which match the OE wiring harnesses for an easy, positive connection. Viton fluoroelastomer O-rings seal the injectors to the fuel rails and intake manifold to prevent fuel and air leaks under extreme operating temperatures. TFX Fuel Injectors include 1/2 micron filter screens to keep debris out of the injectors and are available in 24 lbs./hr., 30 lbs./hr., 36 lbs./hr., 48 lbs./hr., and 120 lbs./hr. flow ratings.
"Our TFX Fuel Injectors deliver the fuel needed to make big horsepower," said Al Noe, Trick Flow Manager. "Plus, they're less likely to become clogged and have electronically drilled and machined internal discs to prevent rich air fuel mixtures. That means optimum fuel economy and maximum performance."
Based in Akron, Ohio, Trick Flow Specialties offers products that provide "Ultimate Bolt-On Performance!". Trick Flow's product lines include cylinder heads, intake manifolds, camshafts, valvetrain components, and more. For product information, visit http://www.TrickFlow.com.
Old Mar 10, 2008 | 07:45 AM
STL94LT1's Avatar
STL94LT1
Good luck!! Let us know how they work.
Old Mar 10, 2008 | 10:26 AM
Kool88vette
I will, it might take a couple of weekends. I just mess with it when I get the urge.
Old Mar 10, 2008 | 04:04 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
We only sell new injectors.
The TFS injectors are the same as our disc injectors.
Old Mar 10, 2008 | 04:08 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
This is the proper injector for a 1988 C4:
http://www.racetronix.com/621022.html
To Trick Flow injectors
