I hate intermittent problems
Old Mar 11, 2008 | 03:11 PM
djf85vette's Avatar
djf85vette
Default I hate intermittent problems
OK, here's the situation. I start it up and it runs great. Drive it around, everythings fine. Next day I start it up, it won't idle. If I apply a little gas pedal it will stay running but if I let off, it dies. Swear a few times, scratch my head and walk away.
A couple days later I try it again. Start it up and it runs great. I didn't do anything to fix it, it just got better. This has happened a few times now. It doesn't run, then it runs fine.
Any ideas what could cause this?
Old Mar 11, 2008 | 04:42 PM
rick lambert's Avatar
rick lambert
Get a fuel pressure guage on it and ohm the injectors, you may have a sticky injector, or more.
Old Mar 12, 2008 | 01:11 AM
vetteracerx's Avatar
vetteracerx
Sounds like a MAF sensor or relay issue.
Old Mar 12, 2008 | 11:54 AM
LouisvilleLT4's Avatar
LouisvilleLT4
A lot of things could cause the car to shut off and I expect you're going to get a ton of different suggestions. If you can find out for sure that the car never shuts off in this way as long as your foot is on the pedal, that helps some in diagnosis, but it may have just been a coincidence up until now.
An red-cover FSM would really help to give you ideas for diagnosing this. Go to helminc.com if you don't have one already. Also, a nice laptop scanner like Auterra would give you a live feed of all your sensors which could help isolate the problem.
Old Mar 12, 2008 | 01:20 PM
SunCr's Avatar
SunCr
Coolant Temp Sensor acts like a choke - the colder the temp, the more fuel it gets. If the signal is wrong; ie, too warm, there won't be enough fuel. Easier to diagnose with a Scanner - but that CTS temp is available through the Digital Display. The next time it won't start cold - see what it is. It should be about the same as the outside air temp. If not, you can buy a $9 replacement and without installing it, simply plug it into the harness. If it now shows the outside air temp, replace it. If it's still skewed, you'll need to troubleshoot the wiring and ECM (though if it's intermittent, I'd suspect the ECM).
Old Mar 12, 2008 | 01:29 PM
LouisvilleLT4
ECT sensors are a simple resistor and rarely fail. It's more likely for the ECT connector to heat-warp and wiggle loose while the engine runs. Happened to me.
Old Mar 12, 2008 | 01:49 PM
cwyates4's Avatar
cwyates4
Sounds exactly like mine was. Idle air control valve may be dirty, or going out.
To I hate intermittent problems
