Exhaust is done...
Old Mar 11, 2008 | 06:32 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Exhaust is done...
It cleared my code 44 and the car idled 100% better. It idles nice, I thought it would be lumpier..
The only problem now is that it backfires and does not seem to run smoothly.
I have to start with the basics.....check timing, wires, firing order, ect.....
Old Mar 11, 2008 | 07:04 PM
Pete K's Avatar
Pete K
Make sure the valves are not too tight. That has bit my azz once or twice.
Old Mar 11, 2008 | 07:08 PM
chad89's Avatar
chad89
Good job! Now, let's hear it.
Old Mar 11, 2008 | 07:45 PM
jsup's Avatar
jsup
OK, here's the last two problems...
Headers turning red. Still missing on a couple cyls.
jsup's Avatar
jsup
You mean hanging open?
Old Mar 11, 2008 | 08:06 PM
mseven's Avatar
mseven
have you put a scan/datalog on it to see what else is going on ?
Old Mar 11, 2008 | 08:09 PM
jsup's Avatar
jsup
Not yet. Byebyel98 is going to come over and help me out with that. Waiting on his availability.
In the interim, this is mechanics 101, should be able to idle smoothly and run without backfiring at this point. Am I assuming too much?
BTW, SOME header tubes are red, not all of the, and not real red, just on the cusp.
Old Mar 11, 2008 | 08:18 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Do you think you might be lean?
Old Mar 11, 2008 | 08:23 PM
jsup's Avatar
jsup
No. I am getting no codes and besides which Alvin (PCM FOR LESS) said if the injectors are too small it will manifest itself at WOT.
I didn't do WOT. It hesitates, then backfires.
Would lean cause a backfire? Rich I can understand, but lean?
Old Mar 11, 2008 | 08:25 PM
mseven's Avatar
mseven
Originally Posted by jsup
In the interim, this is mechanics 101, should be able to idle smoothly and run without backfiring at this point. Am I assuming too much?BTW, SOME header tubes are red, not all of the, and not real red, just on the cusp.
It could be running too rich or lean in closed loop. IMO a scan would help there, have you checked for vac. leaks.
Old Mar 11, 2008 | 08:27 PM
jsup's Avatar
jsup
I just picked the car up, ate dinner, did a quick check of the sparkplug wires, and put it in the garage...no time for a vacuum check.
Old Mar 11, 2008 | 09:18 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Unfortunately, I don't have a free weekend until after Easter. If that works for you, come on up!
If it didn't backfire before the exhaust was done, I would guess that it isn't the valves. DOUBLE check the plug wires as this was the cause the last time you had a glowing header and it was running rough. And not just for firing order - make sure the headers didn't burn up one of the wires. Also, sometimes when pulling the wires off of either the plugs or the cap several times, the wire can separate from the crimp inside the boot. Check the plugs again - if the ECM was reading lean from the heated O2 (in closed loop) all this time, then it has been throwing a lot of extra fuel at them; could be carbon fouled.
Are you getting the back fire when you hit the throttle or during steady cruise? A momentary lean condition when you hit the throttle will cause a back fire (a lean pop) and can be solved via the tune. Back firing during steady cruise could be fouled plugs, bad wires (or crossed wires), timing related, heck even bad gas.
Old Mar 11, 2008 | 09:23 PM
jsup's Avatar
jsup
Works for me. It's a date....
It did backfire before the exhaust was done, I figured that was a result of the O2 picking up a lean condition and putting down more fuel.
I have an engine scope, I'll hook it up. I just may get a new set of wires. First, I'll check the timing tomorrow. I am sure I nailed it at 6* but I'll double check.
Yes, a steady cruse when I either hit it or take my foot off the gas it will backfire.
Old Mar 11, 2008 | 09:26 PM
Pete K's Avatar
Pete K
Yes
Old Mar 11, 2008 | 09:32 PM
byebyeL98's Avatar
byebyeL98
OK - make sure everything is mechanically sound (cover all the bases mentioned here), then put her away for a few weeks until the 29th or 30th, whichever day is nicer .
Old Mar 12, 2008 | 01:17 AM
hexane's Avatar
hexane
If the motor performs sluggishly, backfires from the intake or exhaust and the headers are glow red, that could mean your timing is set way retarded. I would check and see if you didn't accidentally set the base timing ATDC.
Old Mar 12, 2008 | 01:55 AM
staugur's Avatar
staugur
Back asswards.If it's firing through the intake valve before it's closed you are way advanced or the valve isn't closing completely.That would also account for the glowing headers.Check firing order again.You had it wrong last time.
To Exhaust is done...
Old Mar 12, 2008 | 08:15 AM
jsup's Avatar
jsup
I'm going to go over it today.
Old Mar 12, 2008 | 08:51 AM
mseven's Avatar
mseven
I think it is a nice gesture of byebyeL98 to come and help you out...kudos to him
IMO, I think it would be to your best interest in the real near future to go ahead and get a cable and get your laptop loaded up w/d.log. Since you will need this anyways wether you work w/Alvin or not, it would eliminate many questions/possibilities that are currently going on and in the future.
Old Mar 12, 2008 | 09:01 AM
jsup's Avatar
jsup
Will do. I was thinking the same thing
