383 stroker and heads question
Old Mar 12, 2008 | 05:54 PM
airforcefun's Avatar
airforcefun
Default 383 stroker and heads question
hello,
with a 383 fully forged stroker kit, how many CC's should the heads be?
thank you
Old Mar 12, 2008 | 05:58 PM
black_89_vette's Avatar
black_89_vette
Well if you're talking intake port cc's I guess 190-200.
If you're talking combustion chamber cc's, it depends on your desired compression ratio. Most are 63-65 ish.
Old Mar 12, 2008 | 06:21 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Originally Posted by airforcefun
hello,
thank you
Do some research look at AFR, Brodix, Edelbrock. You need an overall plan for the engine, displacement is just one element. Check out specs. at a builder like Golen.
Old Mar 12, 2008 | 06:23 PM
airforcefun
thank you
Old Mar 12, 2008 | 07:12 PM
Pete K's Avatar
Pete K
hello,
thank you
How high is up?
More to it than that. Intake runner cc? Exhaust runner cc? or combustion chamber cc?
If combustion chamber cc, you want the biggest possible chamber to suit your piston availability/compression ratio.
Old Mar 12, 2008 | 08:02 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by Pete K
How high is up?
AFR!!!!!
You guys are getting like me!!!
Old Mar 12, 2008 | 10:14 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Originally Posted by jsup
AFR!!!!!
Glad to see you have come to your senses
J/K
Old Mar 13, 2008 | 02:35 AM
vader86's Avatar
vader86
Generally I'd say 190-200, but the rest of the combination does affect it.
Old Mar 13, 2008 | 04:36 PM
MarkBychowski's Avatar
MarkBychowski
The real answer completely depends on the entire combination and what your desires for the motor are. There is no one answer for your question, though, without knowing what you want to use the motor for and what your goals are for powerband range and levels.
The cam choice has a HUGE impact on head selection also. They should be chosen in tandem. Some of the head porters like Lloyd Elliott or Advanced Induction (as with most good engine builders) will work with you to choose the right combination.
To 383 stroker and heads question
