84 Vette - Ignition Module / Coil Help
Here is the story. I am sad to report that my Crossfire has finely left me stranded. I will add that it did take 10 years and 120k miles to do it. So, I still love my car. It was destined to happen sooner or later.
I was driving down the interstate and the car shut off. I kicked it in neutral and tried to restart to no avail. I pulled over and called my boss in panic as I was on my way to the airport. Was suppose to be in South Florida 4 hours later for a big event. Needless to say I am at home finally with my car. I will not be making the trip.
What I have done so far:
Retrieved codes = the default 12 - no codes
Replaced coil w/ spare from garage = no fire
Replaced Ignition Module from old dizzy = fired up "This module had atleast 80k on it"
I drove car about 1 minute and it back fired pretty loud "Might have blown a muffler off" and then it died.
I pushed car home in saddles as that was what I was wearing. I have no ideas on what to check now.
Do you think the module I replaced it with might have been bad as well? Can a coil cause it to fry?
is what I want to do in order to fix it!
There is an old man who always sits out on his driveway every afternoon. He stared me down as the car was towed into the neighborhood. About 45 mins later I had it running and took it for a spin around block. He practically fell out of his chair when he saw me coming. Must have thought "Man he works fast!!" Then the car backfired in his face and he watched me push it home in dismay.
RACE ON!!!
RACE ON!!!
I did apply the grease to the module before installing.
Off to get tested and purchase more parts
I bought a new module, and used an old coil I had laying around. Everything seems to be working ok! I had them test my MSD coil which they claimed was good. I still put in the coil I removed when I upgraded the ignition components.
Car is running good again!
Thank you all for the help!
RACE ON!!!
RACE ON!!!
