Replacing fuel pump on 84......
Old Dec 7, 2001 | 10:06 PM
Romeo Barrera's Avatar
Romeo Barrera
Default Replacing fuel pump on 84......
I noticed that there is a large capacitor or something soldered onto one of the wires. Can I bypass this or do I need to resolder it to the new harness included with the fuel pump?
Old Dec 8, 2001 | 12:09 AM
Bartman's Avatar
Bartman
Default Re: Replacing fuel pump on 84...... (Romeo Barrera)
I don't know if you know this or not but the 85 fuel pump provides much more fuel pressure and bolts right up. I would not replace your stock pump with another stock 84. definately go with the 85. check out the crossfire forum for more details.
Old Dec 8, 2001 | 01:00 AM
Romeo Barrera
Default Re: Replacing fuel pump on 84...... (Bartman)
Thanks, I did get the 85-87 pump, and AC Delco nonetheless.
Old Dec 8, 2001 | 07:29 AM
Bartman's Avatar
Bartman
Cool,
I never had a chance to do that mod with mine before I sold it. Are you going to make your fuel pressure adjustable? Good luck.
Bart
Old Dec 8, 2001 | 10:39 AM
Romeo Barrera
It's already adjustable from the factory :D You just have to pry off the cover cap and buy a special double-D wrench to adjust it. This is for the Ceasefires only.
Old Dec 8, 2001 | 12:40 PM
john25's Avatar
john25
I replaced my '84's pump with an '85 unit also but I didn't have to change a capacitor. I just changed the pump and wiring connectors because they were different. I used a pump from Autozone.
Old Dec 8, 2001 | 12:48 PM
Romeo Barrera
Default Re: Replacing fuel pump on 84...... (john25)
So you reused the original capacitor or bypassed it?
To Replacing fuel pump on 84......
