g-Force TA drag radials?
Old Mar 13, 2008 | 06:36 PM
AZC4Guy's Avatar
AZC4Guy
Default g-Force TA drag radials?
OK, the car is ready for the track except for DR's. I need 315 35 17's
Any opinions on the g-Force? Opinions on other tires welcome.
Thanks,
Steve
Old Mar 13, 2008 | 07:08 PM
jonecap's Avatar
jonecap
Nitto NT555r's if you're going to run them on the street. MT ET Streets for track only.
Old Mar 13, 2008 | 08:36 PM
xflagz51's Avatar
xflagz51
M/T street radials are plenty sticky, too sticky! If you're using the stock half shafts then be gentle on them. I twisted one out a couple of seasons ago doing burn-outs at 5K RPM and launches at 4.5K.
Old Mar 13, 2008 | 08:43 PM
xrcrx's Avatar
xrcrx
I've got about 75 miles on my 315's. The BFG's are very impressive so far!
Old Mar 13, 2008 | 09:14 PM
pr0zac's Avatar
pr0zac
bfg's would be first for a driver.. or m/t
Old Mar 13, 2008 | 09:28 PM
AZC4Guy's Avatar
AZC4Guy
I should have given more details. I have two sets of rear rims so can use the DR's as track only. Recommendations?
Old Mar 13, 2008 | 09:31 PM
xrcrx's Avatar
xrcrx
I've read more than once that the MT's are awesome track only tires.
Old Mar 13, 2008 | 09:32 PM
pr0zac's Avatar
pr0zac
m/t for sure..
Old Mar 13, 2008 | 10:23 PM
Pete K's Avatar
Pete K
Originally Posted by pr0zac
m/t for sure..
1.525 60' time on my 87 with the mt drag radials
Old Mar 13, 2008 | 10:31 PM
jonecap's Avatar
jonecap
First time I bolted Mickey Thompson's on my car, it picked up the front tires (just a little) launching from idle. They are flat awesome!
I run Nitto drag radials on my street rims and ET Streets on my track only rims.
Old Mar 13, 2008 | 11:51 PM
AZC4Guy's Avatar
AZC4Guy
Thanks guys! MT's it is. I'm gonna put Pete's tranny to the test.
Hmm.. looked at MT's. For open drag nights don't I have to run DOT approved tires? MT has both the DR and the street radial. Which one?
Old Mar 14, 2008 | 06:41 AM
Pete K's Avatar
Pete K
I was referring to the street radials.
Old Mar 14, 2008 | 12:02 PM
AZC4Guy's Avatar
AZC4Guy
After checking out the MT website, I guessed this is what everyone was referring to. Thanks all!
BTW Pete, your tranny is holding up like a champ. Even w/ those big meats on the back, the shifts are snappy and I can spin the tires through 1st and second at will. Good work, lad.
Old Mar 14, 2008 | 04:31 PM
hgh pwr's Avatar
hgh pwr
I ran the bfg 315 on my vette on the street and they are great,the nittos are too hard and don't stick as well on the track.
Now i run the et streets at the track and they are awesome,no spin what so ever.M/T has a drag radial that has a great reputation.
Old Mar 14, 2008 | 07:33 PM
QuikZilver's Avatar
QuikZilver
MT Street Radials. Great tire. Used them on my 01 Z06, so I could drive to the track with them on. My C4 won't be using them, though. I will be running some sort of MTs, but the shop and I are still deciding which ones to run. These will not be used at all on the street...only on the track. Most likely with tubes.
Old Mar 14, 2008 | 11:31 PM
AKS Racing's Avatar
AKS Racing
BFG DRs for the street and M/T ET drags on Alumni Stars for the track (with tubes and screws). The only negative is that it will "haze" the slicks at full boost in 3rd and 4th gear. Not fun, but about the best traction you could want.
Aaron
Old Mar 15, 2008 | 09:31 AM
Pete K's Avatar
Pete K
Thank you sir
Glad it is working as planned. Next time I am out there, a ride is in order.
To g-Force TA drag radials?
Old Mar 15, 2008 | 09:34 AM
Pete K's Avatar
Pete K
I will be running a set of the et streets this year. Not the radial. I will get to see first hand if my Pete K trans holds up.
Old Mar 15, 2008 | 11:56 PM
AKS Racing's Avatar
AKS Racing
I never broke my built 700R4s at the track on slicks, always on the street or highway. I got tired of breaking them (twisted the ears of the convertor, broke the input shaft and broke one of the drums; this gets real old fast), so I switched to a ZF in '98.
The slicks tended to break spindles, and halfshafts, and once one of the u-joints on the main shaft. Slicks and the McLeod twin disk will definitely show you the weak link in your drivetrain (if you are looking for it).
Aaron
Old Mar 17, 2008 | 01:07 PM
DVNCI's Avatar
DVNCI
BFG's here, but after reading about so many guys liking the ET streets better I'm gonna run those after my BFG's are shot.
Not sure about other sizes but in the 345 size on 18's the BFG's are a 30 profile, the M/T is a 35 so a little more sidewall to help you hook.
