Antilock light on my 87
Old Mar 14, 2008 | 09:21 PM
c4cruiser's Avatar
c4cruiser
Default Antilock light on my 87
Noticed a few times lately that the antilock light comes on when I hit a bump in the road. Usually takes a good hit like a pothole and not just small bumps. The light goes out after an ignition switch cycle.
I don't think that the early C4's store any codes as history information in the ECM so the only way to find a error code is when the light comes on. I have access to a Tech-1 at work but that's typically not when the light comes on.
Is this something that may be due to a loose wire or connection? Maybe a bad VSS at one of the wheels? Bad ABS control module relay or possibly the accelerometer?
The ABS works fine and I can hear the self-test every time the engine is started and the car moves thru 4 MPH just as it should.
I have seen the antilock light come on at some autocross events where the surface has a few bumps. Fluid level is fine and I bleed the brakes before each autocross and track day. No signs of fluid leaks anywhere.
Ideas??
Old Mar 14, 2008 | 09:58 PM
JackDidley's Avatar
JackDidley
Sounds like a wheel bearing getting some play in it. The gap at the sensor can change when you hit a bump and trigger the light. May be other possibilities but this is my first choice.
Old Mar 15, 2008 | 01:24 AM
86PACER's Avatar
86PACER
That or loose wiring and/or connectors. Most of which is located under the rear cargo area behind driver's seat where the pump and abs computer is. On a vert, it's under the speaker.
To Antilock light on my 87
