o2 sensor failed after only 10K miles
Old Mar 15, 2008 | 09:20 PM
vetteodyssey's Avatar
vetteodyssey
Default o2 sensor failed after only 10K miles
Hey guys, Just replaced my drivers side o2 about 10K miles ago on my 95. It has a burnt orange color.
I would have to guess that it is running rich. I rest the LT BLM count and haven't driven it much, but the ST counts are around 125 at idle. I do detect a smell of fuel under the hood after I run her.
I'm not burning any oil or needing to add water. Does this sound like I might have a leaking injector?
Old Mar 16, 2008 | 05:32 AM
RRT vette's Avatar
RRT vette
I can't really see detail on the end of the O2 on this computer, so it's hard to read it. It wouldn't hurt to test for a leaky injector and pull the driver side plugs. How did you find out the O2 was bad?
Old Mar 16, 2008 | 10:08 PM
vetteodyssey
The SES light came on so I hooked up a scanner.
There was a LOT of soot on the tip, so I tried to clean it up, but I took off some of the orange color under it.
I drove it today and it ran quite well with the new sensor. I will pull the plug and check it out. Is there an on vehical test for a leaky injector or do I need to pull it?
To o2 sensor failed after only 10K miles
