"sys" Flashing On The Cluster???
Old Mar 15, 2008 | 11:17 PM
MAPLT4's Avatar
MAPLT4
Default "sys" Flashing On The Cluster???
What does it mean when "sys" flashes sometimes in the center of the cluster. Is the ecu detecting something? I usually drive with the temp gauge and sometimes it gets replaced with "sys" flashing. It doesn't happen all the time. It seems like it happens more at night. Can't figure it out. Nothing seems to be wrong with the car.
Any help?
Old Mar 16, 2008 | 05:11 AM
RRT vette's Avatar
RRT vette
It's telling you a code is stored in the CCM. What year C4 do you have?
Old Mar 16, 2008 | 10:54 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
9 times out of 10 it is a weak battery.
Old Mar 16, 2008 | 11:19 AM
STL94LT1's Avatar
STL94LT1
Old Mar 16, 2008 | 12:21 PM
Hotred94's Avatar
Hotred94
The sys indicator is an electrical problem indicator that usually comes on with a weak battery, and electrical problem in the dash (rare), or an aftermarket radio change (because the new radio doesn't have the proper resistance value).
Old Mar 20, 2008 | 06:14 PM
Radco10's Avatar
Radco10
This doesn't do you much good without the illustration, but at least you will know what you're looking for.
This was a TSB issued for this problem:
Radio - Aftermarket Unit May Set DTC`S 72 and 74
Number: 93-68-9A
Section: 9A
Date: DEC. 1992
Corporate Bulletin No.: 238311
ASE No.: A6
Subject:
AFTERMARKET RADIO MAY SET DTC'S 72 AND 74 IN CCM
Model and Year:
1990-93 CORVETTE
APPLICATION:
1990-93 Y-car
CONDITION:
On the 1990-93 Y-car, Diagnostic Trouble Codes (DTC's) 72 and 74 may be set in CCM if an aftermarket radio is installed. "SYS" will be displayed in the LCD section of the cluster, and the DTC's will be displayed when the diagnostic mode is entered.
CAUSE:
With an aftermarket radio installed, DTC's 72 and 74 are likely to be set because the LCD and LED dimming lines to the radio have gone to an open circuit, because these inputs do not exist in an aftermarket radio.
CORRECTION:
1. Disconnect negative battery cable.
2. Remove the radio control head, following the directions in the Service Manual, Section 8C. This will allow access to the radio control head wiring.
3. Add 1K ohm, 1/2 watt resistors as shown in the illustration. The resistors are available from a local electronics supply store, such as *Radio Shack. The resistors should be connected to a 12 volt ignition-switched circuit. For 1991 to 1993, there is an auxiliary power pickup in the console. For 1990, ignition circuit number 300 should be used. See Section 8A for wiring details.
4. Reinstall the radio, then reconnect negative battery cable. Clear the CCM DTC's as shown in Section 8D, and verify proper operation.
If further information is needed, contact the Corvette Action Center at 1-800-457-8388. Hours of operation are 6:00 a.m. to 4:30 p.m. Central Time, Monday to Friday.
"We believe this source and their equipment to be reliable. There may be additional manufacturers of such equipment. General Motors does not endorse, indicate any preference for or assume any responsibility for the products or equipment from this firm or for any such items which may be available from other sources."
Old Mar 20, 2008 | 08:41 PM
10.5Vette's Avatar
10.5Vette
I have the same problem and was going to do the TSB fix, but it might be the battery also, so I was wondering is there a way to read the codes to find out for sure, battery or radio? Is there a way we can get codes off the CCM?
Old Mar 20, 2008 | 08:44 PM
Overboost's Avatar
Overboost
From: Flint Michigan, #2 in unemployment, #3 in Violent crimes
this is the problem I was expericencing and once I shut off the car, and restarted it, it went away.
that was when I was starting it about once a week in 5 degree weather.
if I put a battery charger on it and then started it, it never happened.
weak battery syndrome ......
Old Mar 20, 2008 | 10:19 PM
Radco10's Avatar
Radco10
Checking the codes is simple, on my 91 anyway. I started a thread earlier. Refer to "downloading codes on a 91".
I just did mine. I got a C72, H72, H46, and 1.0. Now all I have to do is decypher them. I know the C72 is because of the aftermarket radio thing, but I don't know what the H72 or H46 are. For the C72, I'll have to put the resistors in per the TSB. But if anyone has other methods, I'm all ears!
Old Mar 21, 2008 | 10:07 AM
NEVRL8T's Avatar
NEVRL8T
Number: 93-68-9A
Section: 9A
Date: DEC. 1992
ASE No.: A6
Subject:
Model and Year:
1990-93 CORVETTE
APPLICATION:
1990-93 Y-car
CONDITION:
CAUSE:
CORRECTION:
Here is the TSB: http://www.corvetteforum.net/c4/dave8476/index4.shtml
Old Mar 25, 2016 | 05:34 PM
Chrly919's Avatar
Chrly919
My 93 was lighting the SYS last fall. I had had it about 9 months at that time and it had an aftermarket head unit. I thought it strange that it took it this long to show up. My battery was doing strange things and I thought maybe it was loose terminals. I tightened those up and put it on the charger and that seemed to fix it. Several weeks later the battery left me high and dry away from the house. Got a new battery and that was that. This fix came to me from using search on CF.
Old Dec 12, 2016 | 12:39 AM
2ljd's Avatar
2ljd
Does anyone have a copy of this TSB? The links don't seem to be working...
To "sys" Flashing On The Cluster???
