the one i prurchased is running about 150's--very possible the temp sending unit may be out-also the digital dash is pretty iffy--thanks ill keep the in the lockbox
CFI can answer this better than I can, but if your car is running that cool, and it would likely be due to a stuck open or missing t-stat, your computer may be operating as if the car is in "start-up" mode and thus running rich. Not to sure on the 84 computers specifically but many newer models give a system extra fuel until it reaches temp.
150°F is cold not warm. Unless you are in Metric mode....which converts to ~300°C
Can you confirm that you are in English or Metric mode???
150° F ~ 65° C. 150° C ~ 300° C. I find it hard to believe that is will sit and idle indefinitely without exceeding 150° F. It may cruise down the highway at that cool, but with no air flow across the radiator it should warm up well past 150° F, and eventually turn the fan on.
psychosurfer,
The 150° F is about the temp my trans will shift to OD and lock the converter. I don't own a scanner and I can't tell you at what temp it goes into closed loop. I'd have to go out for a drive to double check, but I think the cold idle shuts off at about the same temp. I remember thinking just the other day that I wished it would shut off earlier than ir does.
RACE ON!!!
Hahaha
I went bassackwards!! I'm a retard and we now have proof!
