stock 88 vette needs injectors
Matt
I didn't find it all that hard.
As for brand, there's one manufacturer that makes an entire range of brands, so be careful about brand. People will tell you brand "X" is terrific and brand "Y" sucks and they are made in the same factory.
I would recommend looking at TPIS, Racetronix (which I just ordered), the NEW Accel, Holley to name a few. All are DISC, not pintle injectors and are all of equal high quality. Also, depending on price, Autozone and Napa have injectors of same quality in their OEM brands. If you choose any one of those brands you should be getting equal quality, so shop price on those.
Unless you want to do a retune, stick with the stock pressure. If you have no other major mods, changing the pressure won't buy you anything anyway.
I do agree that all the major forms are putting out good products these days. Don't fall into the hype that higher flow injectors are best for your application. There are too many variables. On a stock powerplant, I'd stay with the stock flow rates. Anyway, call TPIS. You'll be glad you did. Very helpfull and VERY much on top of their game!!
Doug Watson / Class Corvette
I ordered a new set of Bosch injectors from an injector rebuilder but ended up with used. I won't let that happen again. I sent them back but the injector rebuilder tried to keep 20% of my money plus the shipping and handling. I got all my money back after I filed a complaint.
So now I'm changing them again. I got a set of Trick Flow injectors from summit racing. They are new and look good. Hope they work OK. Racetronix, summitracing.com or any major auto parts store should have replacement injectors.
Just be sure to buy from an established and reputable dealer. I would buy new, not rebuilts. Stick with something close to OEM.
Changing the injectors is not difficult if you have a little experience. I would get an intake manifold gasket set. You may want to replace a few things while you are in there. It's a good time to replace the EGR valve, thermostat and the TB hoses. If you want to do a TB bypass or a AFPR now is the time.
