Thermostat Change
Old Mar 16, 2008 | 11:40 AM
OBSESHON Mark's Avatar
OBSESHON Mark
Default Thermostat Change
Hi Guys I am going to install a 180 degree thermostat today.
Do I need to drain the complete cooling system first and if so what is the best way to do this?
Thamks.
Old Mar 16, 2008 | 11:51 AM
CFI-EFI's Avatar
CFI-EFI
No. Just open the petcock at the bottom of the radiator and drain a couple of quarts into a container. You can then use that to top it off after you button it up. If it hasn't been done for a while, this could be a good opportunity to do a drain and flush of the cooling system. It is best done every two to three years.
RACE ON!!!
Old Mar 16, 2008 | 11:55 AM
88JDO's Avatar
88JDO
Take the throttle body off for easier access to the thermostat housing bolts. You may as well clean that while your at it. Also the IAC. I've changed my thermostat without taking the TB off but it's more time consuming.
Old Mar 16, 2008 | 02:03 PM
vader86's Avatar
vader86
No just drain a little bit out of the radiator.
If you havent changed the coolant in the last 2 years, it would be good maintenance to do so however.
Old Mar 16, 2008 | 10:51 PM
OBSESHON Mark
Thanks for the Replies.
I didn't get to it today but hopefully I can do it this week.
What coolant do you guys suggest?
Old Mar 16, 2008 | 11:43 PM
vader86's Avatar
vader86
regular old Prestone 50/50 mixed
To Thermostat Change
