RPO Codes
VIN : 1G1AY0781E5117453
1YY07 Base Coupe
AU3 Power Door Locks
A42 Seat, Power, Driver
A51 Seat, Front, Bucket, Passenger, Driver
BGR Bowling Green Production Plant
B16 Processing Option
CC3 Removable Transparent Roof Panel
C49 Electric Rear Defogger
DL8 Mirror, Heated Outside
D9B Vehicle Speed Sensor
E57
E9Z Key Speedo Delete
FE7 Suspension, Heavy Duty
F51 Gas Shock Absorbers
HE3 Axle, Rear, 3.07 Ratio
KC4 Engine Oil Cooler
K05 Engine Block Heater
K61 Generator, 97 Ampere
L83 Engine, 5.7L V8, CFI
MD8 Transmission, Automatic, 4-Speed, 700R4
MX0 Auto. Transmission w/ Overdrive
NA5 Emission System, Federal
NB1 Federal Emissions
PX2
QZD P255/50VR16, Steel Belt Radial Tires
UG4
UU8 Delco Bose Stereo System
V01 Heavy Duty Radiator
V73 Vehicle Certification
W82
Z49 Canadian Base Equipment
Z51 Performance Handling Pkg.
Z6A Rear Window/Side Mirror Defoggers
6L3
63U
651
652
http://members.tripod.com/theviperpi.../maintain.html
...And here's a site with way more than I ever wanted to know about RPO codes...
http://www.corvetteactioncenter.com/tech/rpo.html
[Modified by Rich B., 7:24 AM 12/9/2001]
PX2 - Wheel, Rear (aluminum)
E5Z - Adapter, Speedo Delete
63U - Exterior Color-
65I - Interior Color, Antelope
652 - Trim Combination, Leather, Medium Antelope
Nothing is listed for a "W82", but usually (but not always) a RPO in the W## series is a special marketing or appearance package. The E## series is usually something to do with the body such as a special door, an extra convertible release handle, etc.
Whereabouts in the manual did you find these codes??? I'd like to look up my codes, too! (I have old manual dated 9-90).
Some info regarding the Uxx series of options - these seem to be instrument cluster and/or warning device options. For example there is a UD4-Alarm, Vehicle Speed (120KPH) (Export) and a UB4-Lamp, Side Marker. Nothing is listed for a UG4 though.
I have noticed that sometimes the Service Parts Identification placard is sometimes illegible or "subject to interpretation". For example the "651" code is most likely "65I". A little detective work comparing codes with what is installed will often give the right answer.
Edit: I agre with an above post that UG4 is probably U64 (since you have the UU8 Bose system)
U64 SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL STD RGE
And 651 is probably 65I because you have 652
65I INTERIOR TRIM, MED ANTELOPE (91)
[Modified by Scoob, 2:00 PM 12/11/2001]
