Antenna on a Bose system??
Old Mar 19, 2008 | 12:20 PM
Atomic-Vette's Avatar
Atomic-Vette
Default Antenna on a Bose system??
My nephew is trying to install a new stereo in a 1992 Corvette with the bose system. But he said he can't find the antenna plug. Everything else works fine but there's no FM reception, is the antenna plug in a different part of the car or something?
Old Mar 19, 2008 | 12:40 PM
kalister1's Avatar
kalister1
On my 93 the radio receiver is located in the compartment behind the passenger seat. You have to remove the plastic box and then pull the carpet back to find it. I do not know about the 92?
Old Mar 19, 2008 | 04:37 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Everything you wanted to know about the C4 Audio system:
http://forums.corvetteforum.com/showthread.php?t=941281
The antenna plugs into the actual radio receiver, with is not part of the head unit you see in the dash.
Old Mar 19, 2008 | 04:51 PM
PurtyLilC4's Avatar
PurtyLilC4
the other possible location is under the dash on the passenger side, thats where it was on my 90, those are basically the only 2 places you will find it. Also, you will need an antenna adapter, regardless of which place you find the unit.
To Antenna on a Bose system??
