Fuel pump replacement
Old Mar 20, 2008 | 11:21 PM
StephensblackL98's Avatar
StephensblackL98
Default Fuel pump replacement
At last! An easy job! I've done everything from plugs to heater core to rebuilding an L98. Nothing was ever an "easy" job. But! Fuel pump replacement was a breeze. I bought a new high volume unit from Racetronix, and I've got to say putting it in was a piece of cake. Maybe two hours, max.
I ordered the pump online. It was delivered 7 days later. The site has detailed instructions on how to install the pump. And, everything from new bolts to a paperclip (believe it or not, it was needed) was included in the unit.
I heartily endorse the product. For those of you needing a new pump, and have some experience with minor maintenance, these people put out a very good unit.
Stephen
Plano, Texas
Old Mar 20, 2008 | 11:51 PM
86PACER's Avatar
86PACER
Very easy. Can you believe that the Chiltons manual actually claims that you have to removed the entire gas tank to change the pump? It does.
Imagine that some poor bastard somewhere actually did drop his tank when he did not have to because the Chilton book said.
Old Mar 21, 2008 | 12:27 AM
colin84vette's Avatar
colin84vette
Sure someone that dumb would just write a check at the chevy dealership for the goons there to drop the tank
Old Mar 21, 2008 | 03:01 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Stephen
Plano, Texas
So what did you use the paper clip for?
Old Mar 28, 2008 | 01:27 PM
bowtie350_428's Avatar
bowtie350_428
I guess I would have been the next "dumb bastard" to drop the tank until I ran across this thread. I may soon be replacing my fuel pump on my 91 L98 ZF6. I thought you had to drop the tank to access the pump.
So forgive me for my ignorance but how do you gain access to the pump without dropping the tank? Through the filler port or licence plate?
Old Mar 28, 2008 | 01:51 PM
bowtie350_428
Nevermind, I just answered my own question. Search is your freind...
Imagine that... a task that is easier on a vette than on other cars. It is usually the other way around.
Old Mar 28, 2008 | 02:55 PM
rithsleeper's Avatar
rithsleeper
just did the same thing last weekend trying to fix a stalling problem and slow startup. I was so pleased with how easy the job was, unfortunatly it didn't fix the problem.
When I first read the manual before installing it said step 1: Remove Gas Tank. I almost flipped out. Then after taking a look at it I realized they were full of *#&@.
Old Mar 28, 2008 | 03:27 PM
86PACER's Avatar
86PACER
http://forums.corvetteforum.com/show....php?t=1718223
Old Mar 29, 2008 | 02:11 PM
bowtie350_428
Thanks 86Pacer! Complete with pics and everything! It is also interesting to know that ZR1s have 2 fuel pumps.
Old Mar 29, 2008 | 03:48 PM
WW7's Avatar
WW7
Maybe they made this job easy to compensate for us having to do that dam Heater Cord.
Old Apr 16, 2008 | 12:24 PM
gsuuod's Avatar
gsuuod
3rd Gear
Stephen - my name is Jerry, user name "gsuuod" and I am trying to replace my fuel pump in my 1994 C4, unfortunately I got my parts from mamotorworks and their instructions are like the Chilton ones you mentioned in your thread I just saw( drain and remove tank, etc.); can you help me? I just joined this forum and I don't know the "in's & out's" very well. Would it be possible for you to let me use the "easy" instructions you were fortunate to get? E-mail = fgmjr@comcast.net
Old Apr 16, 2008 | 02:56 PM
F1Fan's Avatar
F1Fan
It's used to push out one of the wires from one of the old connectors so that it can be reused on the new harness.
To Fuel pump replacement
